Light Tent Built
oxx44
Kitchener, Ontario, Canada
I finally have it done now, just working on settings on the camera and getting use to the new set up.
Alot of variables go along with taking photos, never realized it before.
Well here are some photos of the tent I made. Seems to work pretty good I do see a difference in quality now with the photos. I did post a few in the Show Off Your Pen section. They are untouched and I still have a long way to go.
oxx44
Did you keep track of the cost to build it, I'd be interested in knowing.
Everything was from stuff lying around the house or scrap leftovers. The PVC was actually from outdoor dog bed/tents. But my Cooper destroyed one so I just recycled what I could. The lexan Sheets I have had for about 2 years and never used it. Came from a friend. I did buy the lighting though. $10 a fixture and 15 for a 4 pack of 23w daylight bulbs (Home Depot). So I did spend $50 on lighting.
hanau
thomasville, nc, USA.
oxx44 could you post what the proper name for the light fixtures or where i can find them?
Also on the lights are the the energy saver fluorescent or incandescent bulbs?
I was at lowes they couldn't help me with the fixtures and ask about the bulbs the guy said they are over there on the first aisle.
MyKidsDad
Edmond OK
oxx44
As for the bulbs I still have the box so I took a pic for you.
For the fixture, you are looking for something like this http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
You are absolutely correct. These are the exact fixtures I got from HD.
Hope this helps keep us posted.
hanau
Thanks Found them at lowes. Didn't pick them up yet. Going to have to get a box put together first.
How did you attach the fabric to the pvc pipes?
oxx44
its not fabric. I used plastic sheets (lexan).
but my prototype had fabric. I just laid it over the pvc and stapled it to a heavy piece of wood. Gravity stretched it and held it in place.
ctubbs
Murray, Kentucky
I haven't yet built this, but it seems like it would be a big help in lighting our small projects. It is a ring light using LEDs. Here is the link;
http://www.instructables.com/id/Build-ring-light-for-your-camera/
The old very expensive ring-lights provide a shadow-less environment with even lighting.
I agree, digital has never matched film in quality, and most probably never will just by the technologies involved. Film has very high and random resolution where digital is all lined up in rows. However, digital is still very handy.(New convert)
This is my first post so please just forgive my ignorance.
hanau
How thick was the lexan was you using?
Any closer pictures of the assembly?
oxx44
I am using 1/8 inch Lexan all around.
I hope these pics will help you more of what I did.
The top piece is NOT screwed in it is a tight fit between the PVC and the side lexan pieces that are screwed in. I left A high lip on the black lexan that is heated and bent in the middle and the front. The High lip is just for mounting the squeeze claps from the lights. The PVC works for the lights as-well, so Light placement possibilities are endless. I only curved the front lip cause I didn't want a straight edge there for me to hit while taking photos. No real purpose for this curve.
I just used a heat gun to bend the lexan, ( I learned some patience on this one.) keep the gun moving and when the lexan is hot enough it will start to sag. Let gravity pull it down.
I hope this helps a bit. Let us know how you are making out. Gotta see some pic's when your done.
