Anyone use a fold up light box.
chartle
Pgh, PA
One like this.
https://www.banggood.com/9-Inch-Por...ing-Cube-Soft-Box-p-1168027.html?rmmds=search
I have a cloth photo cube but it takes too much time setting up.
TonyL
Georgia
I like the design, but the sides look somewhat opaque; I wonder how well they will diffuse light.
tonylumps
newtown square pa
Here is the FotoFox light Box I am using the grey back ground.Maybe I tried the White, too bright.
flyitfast
San Antonio, TX 78247
I have a fold up box from Polaroid that works well. However. like most fold up units it does take time to setup. All the lights and stands fit in pockets that are part of the "kit". The lights are kinda wimpy but give fair pictures. I have added a couple of light bars that fit over the top. It came with four colored backgrounds, but I almost always use a graduated gray sheet that I added to the setup. I would add a picture of it but don't time right now to set it up!!!
Wish I had a place to leave it setup, but the dining room table gets frowned on. :biggrin:
A better camera would help also for better pictures.
Most of mine are spur of the moment pictures, so the cell phone gets used a lot.
Gordon
Bob in SF
San Francisco
This one works well for me - got it on amazon.com:
LimoStudio 16" x 16" Table Top Photo Photography Studio Lighting Light Tent Kit in a Box, AGG349
- Bob
Sahuarita, AZ
I made my own light box out of white cardboard. It seems to work perfectly for my application.
That's what my light box looks like.
Here's a picture of what I can get out of it.
chartle
Pgh, PA
I have a fold up box from Polaroid that works well. However. like most fold up units it does take time to setup. All the lights and stands fit in pockets that are part of the "kit".....
The one I linked to unfolds and there is one light strip already installed. You just unfold it and plug in the lights to a 5v mini USB.
leehljp
Member Liaison
Tunica, Mississippi,
These type were popular a few years ago for several members here:
https://www.amazon.com/Neewer-Shoot...3&sr=8-3&keywords=light+tents+for+photography
I hope you get something started again. It certainly is telling for those who simply take a picture of a pen versus those who use decent diffused lighting.
I am not a fan of the strip multi dot LEDs though. If diffused it may be OK, but direct multiple LED light on a finely polished finish will cause multiple reflection points, making it difficult see a continuous reflection finish. As an example, look at the current front page pen photo "Chittum Burl Set by firewhatfire" Notice the finish reflection - it is one long reflection. Multiple light points make that difficult to see, and some may like that. For me, a good photo will also show the skill of a fine finish, as does the photo noted.
Crossgates, Scotland
It doesn't fold up but I made myself a small lightbox to photograph small items from odd bits I had lying about the workshop, cost me next to nothing to make, seems to work quite well
vtgaryw
Milton, VT
I like the design of that box. Is the streak of light across the middle of the picture the vertex where the bottom meets the back? The pictures are great but I'm not sure I'd like that streak.
Gary
Marmotjr
Rome, Ohio
There was a decent one on amazon that was listed as a Prime day deal I was Eyeballing, but I didn't pull the trigger.
I have a whole bunch of 24"x24" .010" polystyrene sheets from a vacu forming project that never launched, so I'm planning on making a box with those. I already use them on the clamp on shop lights with daylight balanced bulbs. One without the poly diffuser for the main light, and one with the poly, just clamped to the rim of the hood, as the fill light. Works pretty good.
CreativeCanes
Oakdale, Minnesota.
I use one that looks the same. I find it works great, I still need to adjust the brightness a little with a photo editor, but I picked mine up for $7 on Ebay and it is worth the small cost in my opinion. The sides are a little flimsy but it came with a white background and a black, I just plug it into my laptop and it's good to go. I found I didn't need any other lighting apart from the led's that's attached to it. Easy to set up and use.
Carl Fisher
Cape Coral, FL
Nokesville, Virginia 20182
I have that one and generally like it, especially for quick photos. My biggest complaint is that (as someone else noted) the string of LEDs along the top front edge reflects off of the item like a series of hotspots rather than diffuse light. Haven't found a way to easily resolve that yet, otherwise I like it.
For TonyL: the sides are pretty opaque because it is designed to just use the string of mini LEDs mounted inside that flap you see running across the top front. I wouldn't use it for external side-lighting. I drag out the bulkier fabric-sided box when I need the really good diffuse lighting.
Carl Fisher
Cape Coral, FL
You can sort of get around that with another light sitting on top of the box. I have a pair of matrix led lights and if I need a softer light I'll put one of those on top of the box. Seems to work pretty well (like this one: https://www.amazon.com/dp/B004TJ6JH6)
BeeAMaker
Elkhart IN, USA
PenPal
Canberra, A.C.T., Australia.
My open light box is a conduit frame easily made flat by removing the four legs sitting on a two inch foam sheet. Works for me every time with a light either side and a top light sits on the frame.Takes me but a few minutes to take a pic then 5 more minutes to post.
Peter.
Rockytime
Arvada, CO 80003
Peter.
I like it.More than adequate. Used outside no lights needed!
