The $5 solution to shadows
mmayo
Tehachapi, CA
I usually shoot with a black background because that was easiest, gave good results and I could do it. Here is a lighter background experiment with results that cost $5 for a large sheet of Duralar 5 mil matte material from a local art supply place. I rolled it and trimmed it to form a photographic cone diffuser. Mine is tall since I use a somewhat long 100mm macro lens; yours might be less tall if you use a shorter lens like a 50mm. I used masking tape to secure the cone and can roll it up in a narrow tube for storage.
The cone
Before the cone with two lights
With the cone
First, sorry I moved the setup between shots, it just had to be done. Second, I used a tripod to shoot straight down on my pen. Several factors are changed with the addition of the cone: contrast is lowered (not always good), shadows are reduced to almost elimination, harsh highlights are made more subtle.
This is a new setup and suggestions are welcome. If it helps you that would be great too.
plantman
Green Bay, Wi
Doesn't this limit you to shooting straight down?? Add a third light behand and above your subject, and you won't have the shadow or be working on the floor, and can shoot from any angle and at a comfortable height. Also a white base will give you light reflection. I use a white terry cloth towle when I shoot. Make sure keep any wrinkels out unless you use them for effet. Jim S
Dan Hintz
Columbia, MD
I agree with the third light on a normal tent, though I give full credit for a tent design that really does break down in 5 seconds and lie flat. As long as the top-down approach doesn't bug you too much, I say stick with it.
mmayo
Tehachapi, CA
After playing with this first trial I plan to cut a front door in the cone to allow both top and angled front photographic access.
