TMI Hold Fast - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > IAP Marketplace > Vendor Forums > TurnTex Woodworks--Cactus Juice
  Forgot Password
TurnTex Woodworks--Cactus Juice The Original, Affordable DIY Stabilizing Solution.
Welcome to penturners.org!
Reply
Old 12-18-2017, 09:30 PM   #1 (permalink)
Photos: 0
Default TMI Hold Fast
TMI products hold fast vacuum pump. Is it any god for stabilizing? Could I use their chamber and pump with your resins?
JPW062 is offline   Reply With Quote Top
Old 12-18-2017, 11:10 PM   #2 (permalink)
Retired Head Moderator
MesquiteMan's Avatar
Photos: 18
Default
Hold Fast does not sell a vacuum pump, they sell a vacuum generator. Vacuum generators use your air compressor to create vacuum through the venturi effect. Most venturi vacuum generators, especially the one you mention, will not pull a very deep vacuum. The one you mention is rated to 25" Hg at sea level. That is a 83.5% vacuum. In other words, the best you can do is remove 83.5% of the air from your wood. The more air you remove, the more resin you get back in and the better your blanks will be stabilized. There are MUCH better options for less money that don't make your air compressor work overtime.
As for the chamber you mention, if it is the metal one, it is only rated to 27" Hg at sea level and has been known to implode at deeper vacuum commonly used with stabilizing.
__________________
Curtis O. Seebeck
The original, affordable home stabilizing solution!
Now available exclusively from TurnTex...Alumilite Clear and White in 1 gallon kits (1/2 Gal A&B)
www.TurnTex.com
MesquiteMan is offline   Reply With Quote Top
Old 12-20-2017, 08:55 PM   #3 (permalink)
Photos: 0
Default
Great info, thank you.
Advertisement
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
