Robinair vacuum pump - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > IAP Marketplace > Vendor Forums > TurnTex Woodworks--Cactus Juice
  Forgot Password
TurnTex Woodworks--Cactus Juice The Original, Affordable DIY Stabilizing Solution.
Welcome to penturners.org!
Reply
Old 05-31-2016, 07:39 PM   #1 (permalink)
gimpy's Avatar
Photos: 4
Default Robinair vacuum pump
Good Day Bruce,
Great presentation you had at Virginia....I had talked to you after your 1st presentation and we got talking and I told you that I had purchased from the "the other company"......and you told me that with their vacuum pump my air compressor would run for every.........Would you please advise me of a "GOOD" Robiniar vacuum pump,PLEASE.......also, I had purchase this several years ago and wondering if the juice would still be any good......After I get the correct vacuum pump I will purchase what ever else I may need from you......such as gauge, plastic tubing, and 1/4 turn shut off, plus what ever else you may recommend..........Thank you for the load of knowledge you share, and I'm starting to get orders already.........one person wants a stamp pen, and a few other personal blanks......thanks again, terry (aka, gimpy)
gimpy is offline   Reply With Quote Top
Old 06-01-2016, 01:36 AM   #2 (permalink)
Retired Head Moderator
MesquiteMan's Avatar
Photos: 18
Default
Terry,
I remember you well! The vac pump I recommended was a Robinair 15310 for a descent, cost effective pump. If you are looking for the best quality and American made, I recommend a JB Eliminator but they are about 2.5 times the cost of the Robinair.
As for the resin, if it has not bee activated, it will be fine. If it has already been activated, it may or may not work. You can test it by pouring a cheap shot glass full and putting it in your oven at 200 F for 1 hour. If it cures, it is good. If it does not cure or cures like jelly, it is bad. Depending on how much you have, it may be possibly to add more activator and make it like new again.
Hope that helps some!
__________________
Curtis O. Seebeck
The original, affordable home stabilizing solution!
Now available exclusively from TurnTex...Alumilite Clear and White in 1 gallon kits (1/2 Gal A&B)
www.TurnTex.com
MesquiteMan is offline   Reply With Quote Top
Old 06-01-2016, 06:28 PM   #3 (permalink)
lorbay's Avatar
Photos: 134
Default
Quote:
Originally Posted by MesquiteMan View Post
Terry,
And where would one get this activator from. Do you sell it separate. .??
Lin
__________________
"If you come to a fork in the road Take It."
Yogi Berra.
lorbay is online now   Reply With Quote Top
Advertisement
Old 06-01-2016, 08:22 PM   #4 (permalink)
gimpy's Avatar
Photos: 4
Default
Quote:
Originally Posted by gimpy View Post
Good Day Bruce,
Thank you Curtis, I don't know who the hell Bruce is...lol
Old 06-01-2016, 10:45 PM   #5 (permalink)
Photos: 1
Default
Just my 2 cents - I have the JB Eliminator and could not be more satisfied.
hubert is offline   Reply With Quote Top
Old 06-02-2016, 01:10 AM   #6 (permalink)
Photos: 18
Default
Quote:
Lin
I offer activator on a case by case basis. I do not offer it as a purchasable item on my site because if someone adds too much, the resin could go off if you look at it wrong! I require that you do a cure test as mentioned above, then let me know the results of the test including the consistency of the cured resin if it does cure. I also need to know what you have been stabilizing in that resin, how long you have had it, and the quantity you need to rejuvenate. The reason for the last questions is because if you have been doing oily wood, oil from the wood can contaminate the resin to where it will not cure properly and it is a waste of money to add more activator. Also, I only offer activator in 1/2 gallon and 1 gallon quantities so if you have less than 1/2 gallon, I can not help.
Once I know this information and we determine it is a candidate for rejuvenation, I will send for just the cost of postage as a service to my customers.
__________________
Curtis O. Seebeck
www.TurnTex.com
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
