Carl Fisher
So besides the clip, is there a difference between the Zen and the Zap?
Inquiring minds want to know.
I actually prefer to have the back threaded. I can assebly the pieces, then unscrew and flip the ends to see which way feels better in the hand. But that's just me
Ed can answer best.
No black ti option.
I believe the the back may be one piece rather than having a threaded insert.
Plating requires a high level of trust. They can tell you it's black ti, how do you know?
If a manufacturer has already shown they are not hindered by the need to be honest, why do you believe anything they say, that you can't verify, independently?
So assuming the cap/magnet issue is being resolved, will the magnet be as strong as the Zen and Vertex eventually?
If you were to put these side by side with a zen, are they roughly the same size in length and diameter or is the Zap smaller? Is the tube size the same or close? I assume it will accept the Schmidt rollers like the 5888?
Given the questions posed so far, is this a kit that is expected to stick around or was this a trial run?
