Virage Components - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > IAP Marketplace > Vendor Forums > ExoticBlanks.com -corner of IAP!!
  Forgot Password
Welcome to penturners.org!
Reply
Old 05-13-2018, 12:41 PM   #1 (permalink)
Photos: 0
Default Virage Components
I just thought I'd send a note to let you know about a somewhat minor issue I've had with recently received Virage ballpoint components. The clip will not slide over the finial transmission adapter. I first tried with the clip finished in gunmetal, and thought it just might be too heavy of a plating, but, the same was true of the chrome kit I assembled today. I was able to grind down the inside diameter of the clips with a Dremel tool, and then they worked fine. Not a huge issue, but, I thought you might want to touch base with Berea and see if anyone else has reported the problem.
Larry Reitz
Larryreitz is offline   Reply With Quote Top
Old 05-13-2018, 01:15 PM   #2 (permalink)
Photos: 0
Default
that happen in mass production, however you were able to fix it, good job how to solve.
Dieseldoc is offline   Reply With Quote Top
Old 05-13-2018, 02:15 PM   #3 (permalink)
magpens's Avatar
Photos: 75
Default
The fit has been marginal for a long time. It's a little worse on some platings than others
I made a wood tube with ID just slightly over the OD of the finial adapter stub.
I use a pen press and this wood tube to press the clip on.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Advertisement
Old 05-13-2018, 03:34 PM   #4 (permalink)
Photos: 0
Default
Thanks for the replies. Even if it is a bit more effort, IMHO the kit is worth the effort.
Larry
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
