Reminds me of algebra!! - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > IAP Marketplace > Vendor Forums > ExoticBlanks.com -corner of IAP!!
  Forgot Password
Welcome to penturners.org!
Reply
Old 05-15-2016, 11:36 PM   #1 (permalink)
Local Chapter Manager
ed4copies's Avatar
Photos: 27
Default Reminds me of algebra!!
"O" does NOT equal "Q", so, solve for "Y".
Making a perfect fit pen to show how to assemble (next vid coming). Brass tubes seemed to go in awfully easy, but lots to do, so glue and move on.
Turned the blank, shattered from one end---recognized that the hole looked too large. Time to make another pen, so I paid attention when I grabbed the drill bit---"Y" the blank shattered----used a Q size bit instead of O!!
Hope I can save you from the same problem---it does NOT work!!
Vids coming---"how to assemble" series will be underway this week. I am starting to like the results --my GoPro camera has found an application for itself!!
__________________
Ed Brown
ed4copies is offline   Reply With Quote Top
Old 05-16-2016, 12:53 AM   #2 (permalink)
CREID's Avatar
Photos: 32
Default
Sounds like you need to watch some of your videos.
__________________
Curt
That's right I'm fat. Deal with it.
CREID is offline   Reply With Quote Top
Old 05-16-2016, 12:54 AM   #3 (permalink)
CREID's Avatar
Photos: 32
Default
Sounds like you need to watch some of your videos. And by the way, I relate, just used a 27/64 when I needed a 25/64.
__________________
Curt
Advertisement
Old 05-16-2016, 01:46 AM   #4 (permalink)
magpens's Avatar
Photos: 75
Default
Been there; done that ! :(
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 05-16-2016, 02:27 AM   #5 (permalink)
CREID's Avatar
Photos: 32
Default
Wow, how there came to be two post of mine above, I have no idea.
__________________
Curt
Old 05-16-2016, 07:05 AM   #6 (permalink)
randyrls's Avatar
Photos: 68
Default
The first time I make a new pen, always ignore the instructions as to drill size. Use a smaller drill and check the tube fit. Step up to the next larger drill bit until you find a good slip fit. Print out and write the bit size on the instructions. I often find the best drill bit isn't the one on the instructions. Different drill bits may be used for wood versus acrylic.
__________________
Randy S.
I got my WHOLE BODY tattooed, but I didn't want to be conspicuous, so I had them use invisible ink. ---- Stephen Wright
~~~~ Add Your Postal Code and Country to the UserCP ~~~~~
randyrls is offline   Reply With Quote Top
Old 05-16-2016, 07:56 AM   #7 (permalink)
edicehouse's Avatar
Photos: 0
Default
I need to print this out and put it up in my shop, so when I jack something up, I will know I am not the only one it happens to.
edicehouse is offline   Reply With Quote Top
Old 05-16-2016, 08:49 AM   #8 (permalink)
Sylvanite's Avatar
Photos: 35
Default
It's my habit to hold the tube up to the tip of the drill bit (just to double-check the size) before drilling the blank. I can easily verify that the flutes are slightly wider (but not too much wider) than the diameter of the tube. I don't know how many times that has saved me from using the wrong drill bit.
I hope that helps,
Eric
Sylvanite is offline   Reply With Quote Top
Old 05-16-2016, 09:52 AM   #9 (permalink)
hcpens's Avatar
Photos: 6
Default
The people that make the machines and develop the programs that etch the TINY numbers\letters on the drill bit shaft have 200/200 eyesight and have never had to squint or get a magnifying glass with two flood lights just to see a partially worn off fraction or letter.
HE, HE, their time will come!
__________________
With thought and vision, nothing is impossible - open your mind and close your eyes, to see anything!
HCPENS 2012
78223-2300
hcpens is offline   Reply With Quote Top
Old 05-16-2016, 10:39 AM   #10 (permalink)
Photos: 0
Default
I can so totally relate. Even here I have to use a larger font at times to read what is posted here. At times I can read things better without my glasses.
Already looking to the fall and having eye surgery to fix the 'foggy' conditions that are happening. Doctor says things will be alot better.
Glad to read Ed that you are helping the rest of us to avoid the mistakes you make. Sadly, not all mistakes can be helped. We are all human and as such, will make mistakes at times. Thanks for trying.
__________________
It's not "Having what you want"......it is "Wanting what you have".
"Don't go riding on that long black train."
stonepecker is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
