PR_Princess
Will points accrue for a few particular prizes or for "store credit"?
Good Question Dan!!!
Short answer....Yes! But you decide which.
Points will be rewarded based on your purchases. It includes everything on the Exotics site, except partner blanks.There is no minimum or maximum and points will not expire.
You can choose to use the points right away (off of your next purchase), or save them for that something special - its totally up to you. The computer will show you your points right on the check out page and ask if you want to use them.
The only real drawback is that you do have to be logged in and to use or get points. But it should work if you go thru the either the Exotics check out or payments by Amazon....as long as you are logged in.
We have installed a new "remember login" check box to help with the login bit, but once you get used to logging in it should be a breeze. Also you should see that there is an active "Rewards" tab in your customer account now. That should help in keeping track of all of your rewards points for you.
As time goes on and we get more familiar with the software, we may run special sales or events...but first we want to get out feet wet and how everyone likes the new program!!
