Norseman drill bits any interest?
airrat
chandler, az, USA.
http://www.fairburyfastener.com/norseman.htm
Would anyone be interested in a group buy on "Norseman" drill bits. OR if you are looking for a set they are having a sale near the end of the month. I will try to get the date on this.
Here is a link to single size bits it shows the quantity needed to get a 35% discount.
http://www.fairburyfastener.com/norseman_db.htm
If there is enough interest I do not mind running it but I have not run one before and would need a little help from someone that has. If anyone wants to call them to do just a single order I have been working with Frank one of the sales reps.
If interested post what you might want so I know.
leehljp
Member Liaison
Tunica, Mississippi,
Tom,
Thanks for the Link! I can use that in the future.
I just found a hardware store here in Japan with metric bits in .1mm (point 1 or 1/10th mm) increments from .5 all the way to 13mm. But these are VERY expensive. About $35.00 for each bit from 12 mm and up. I sure would like to be able to purchase a set of those.
Dario
Austin, TX, USA.
For what it is worth...of all the drill bits I've tried, Norseman bits are the best IMHO.
To those who are just starting and haven't tried these yet, this is your chance. [^]
airrat
chandler, az, USA.
Chuckie if you click the second link I have you can order individual bits. the right side shows how many we need to order to get the discount. here is a cut and paste of it, basically its buy either 6 or 12 and get 35% off. The list below shows the amounts.
We can also get larger then the 1/2", I called them on that today, I was looking for a 35/64 bit, they didn't have it in stock but were ordering.
the site compacts this so its kinda confusing. go to the 2nd link I posted and its cleaner.
PART NO...TYPE...SIZE...PRICE EACH @ 1...DISCOUNT @ PACKAGE
NOR 05580 190-AG 1/16" 1.17 -35% @ 12
NOR 05590 190-AG 5/64" 1.22 -35% @ 12
NOR 05600 190-AG 3/32" 1.24 -35% @ 12
NOR 05610 190-AG 7/64" 1.33 -35% @ 12
NOR 05620 190-AG 1/8" 1.51 -35% @ 12
NOR 05630 190-AG 9/64" 1.60 -35% @ 12
NOR 05640 190-AG 5/32" 1.70 -35% @ 12
NOR 05650 190-AG 11/64" 1.77 -35% @ 12
NOR 05660 190-AG 3/16" 2.13 -35% @ 12
NOR 05670 190-AG 13/64" 2.33 -35% @ 12
NOR 05680 190-AG 7/32" 2.38 -35% @ 12
NOR 05690 190-AG 15/64" 2.57 -35% @ 12
NOR 05700 190-AG 1/4" 2.80 -35% @ 12
NOR 05710 190-AG 17/64" 3.34 -35% @ 12
NOR 05720 190-AG 9/32" 3.58 -35% @ 12
NOR 05730 190-AG 19/64" 4.02 -35% @ 6
NOR 05740 190-AG 5/16" 4.27 -35% @ 6
NOR 05750 190-AG 21/64" 4.57 -35% @ 6
NOR 05760 190-AG 11/32" 5.39 -35% @ 6
NOR 05770 190-AG 23/64" 5.74 -35% @ 6
NOR 05780 190-AG 3/8" 6.25 -35% @ 6
NOR 05790 190-AG 25/64" 6.83 -35% @ 6
NOR 05800 190-AG 13/32" 7.21 -35% @ 6
NOR 05810 190-AG 27/64" 7.54 -35% @ 6
NOR 05820 190-AG 7/16" 8.47 -35% @ 6
NOR 05830 190-AG 29/64" 9.36 -35% @ 6
NOR 05840 190-AG 15/32" 9.95 -35% @ 6
NOR 05850 190-AG 31/64" 10.24 -35% @ 6
NOR 05860 190-AG 1/2" 10.52 -35% @ 6
Chuck Key
Richmond, Virginia, USA.
The bit I am interested in is not on the list you mention. If you click on the link near the top of that page that takes you to the Norseman site then click on catalog it is listed there with no price.
Chuckie
bruce119
Franklin, NC, USA.
I would be in for a set. I really don't know what I want like a complete set of common sizes we need. Something thatwould work on antler. Iknow the cheap bits don't last at all on antler. I wiped out a bit after 3 antelers.
Woodlvr
Midvale, Ut,
Are the Norseman bits the Parabolic Flutes that I have read about? I would like to order some of these but was not sure if the new (?) style is that much better or not. TIA.
Mike
airrat
chandler, az, USA.
Mike I don't believe they are parabolic flutes, but I am not an expert. I did not see anything on their site saying that. Here are the bullets off their site.
Substantially longer cutting life - The nitro-carburized flute has an increased Rockwell hardness.
Cuts harder materials - The flatter point takes a smaller chip. More torque is directed to a smaller area. This allows drilling into materials with hardness of over 30 on the Rockwell "C" scale.
Stops drill walking - The split point design gives accurate starting without the use of a center punch.
Holds tighter hole size - The split point design is self centering. This limits the normal oversize drilling characteristics.
Outstanding quality appearance - The rich amber gold color sets it apart from commodity cutting tools.
Runs cooler, uses less torque - 135° point takes a smaller chip resulting in less heat. Friction is reduced by amber gold surface treatment.
I can tell you that I am using them right now and the only wood that "fills" the flutes is oily (cocobolo ect) ones. I have drilled Ironwood with no problems, 308 casings and more. I have finally resharpened my 10mm after about 9 months of using and I am not sure it needed it. I have some brad points that I have used once and will not use again.
airrat
chandler, az, USA.
Yeah Gary I will, just waiting to get all the info. I was not sure what everyone would want to look for. I am going to call them tomorrow and see if he got the email. I know to get the discounts we need to get full packs. That is 12 of the smaller bits (same size) and 6 of the larger (same size). If we don't get the full packs we still get them at a good price, the 35/64 bit I called them about for me was going to run $17 or so, it is normally $26 and from others places I have seen it at almost $20.
Then I just need a little help from someone that had done group buys to make sure I dont miss anything.
airrat
chandler, az, USA.
going to paste the email I got from him for the metric bits. The first number he list is if we dont meet the quantity discount for that size, the second one is the discount. Basically its discounted if we buy the entire pack.
GOOD AFTERNOON TOM…..HERE ARE THE PRICES YOU REQUESTED……THE FIRST NUMBER WILL BE FOR INDIVIDUAL AND THE SECOND IS FOR A PACKAGE….THE 6 AND 7MM PKGS COME IN 10 ALL THE OTHERS ARE 5 PER PACK
6MM 2.70/1.76
7MM 3.49/2.27
8MM 4.64/3.02
8.2MM 5.02/3.26
10MM 7.25/4.71
10.5MM 8.38/5.45
11MM 8.88/5.77
12MM 10.09/6.56
12.5MM 10.69/6.95
AND THE 13.3 IS UNAVAILABLE FROM NORSEMAN
THE “TAPER†SIZE I NEED MORE INFO ON THAT ONE….LET ME KNOW…THANK YOU SIR
Let me know what you all think. If you want to have a go at it or not.
JimBobTucson
Vancouver, WA, USA.
Outstanding prices!! We shouldn't have any problems meeting minimum quantities. So let's make this happen. I can not wait to get some good quality bits in the shop.
wudwrkr
Newark, CA, USA.
I too am interested, but this looks like it will be tough to manage since the quantity price for bits are dependent on whether they are purchased in multiple packs. For example, if the group orders a total of 16 7mm bits, that is one 10 pack at $2.27ea and 6 individuals at $3.49ea. At least that is how I am reading it. It would be nice if they could give us the discounted pricing as long as we meet the minimum quantities?
Have they said if they would discount the sets if we ordered them in quantity?
I have the 29pc set and I really like it. I wouldn't mind supplementing it with the metric and numbered sets.
airrat
chandler, az, USA.
Dave I will call him tomorrow on that. I also have the 29 pc set and the reason I got in touch with them was to get the metric set.
Mike I know they have those sizes farther down the list on the 2nd link in my origional post. I will double check with them on it.
bruce119
Franklin, NC, USA.
Boy this is starting to sound complicated. Like I said I am interested but don't really know what I want. Do they have a set or maybe we could put a set together of the common sizes we use. I do want nor can I afford everyone. I don't do a wide veritity of kits but I am sure that will change so I want to be able to grow. I'll leave it your expertise to put a set together.
Mikey
Cleveland, OH, USA.
This almost seems like everyone is going to have to submit the order, the orders will be tallied, then depending on qty ordered totals will then go out. People will then have to pay. Seems like a total PIA, but 35% discount seems like a good reason two own two as it would only cost a little more for the second bit. this may help meet qty numbers if the need arises. A lot of the prices are cheap enough without a discount, but the savings is nice.
airrat
chandler, az, USA.
Bruce the only sets are the ones they have. I am going to list all the common sizes for kits and let people choose from them what they want.
Mike you may be right in how it will have to work, I have an email to them asking how they would work the discount.
IPD_Mrs
Zionsville, Indiana
Where is that list????:)
Also where does this buy stand right now?
airrat
chandler, az, USA.
I am waiting on a response from them still. Sorry I worked 12 hour days Fri, Sat and Sunday. I am going to work on the list today and will hopefully post it in a separate thread tomorrow, if I get a response from them today. I am not sure if they are closed for the holiday or not.
airrat
chandler, az, USA.
I have gotten all the answers, now I am trying to write up the group buy. Here is the hard part.
They work their discount off packages. Basically if they come in a package of 12 and we order 12 we get 35% off. If we go under that we get the individual price. If we go over that we get the discount for the number in the package and the individual price for the over.
My proposal on going over is: If we go over the package amount per size of bit, (we get an order for 9 and the package is 6) I will total up the 6 @ 35% off and 3 at the individual rate and divide by 9. That means we wont get 35% off for everyone but we will get a % off for everyone.
This buy is going to be slightly complicated due to that reason and the shipping from them to me. They cannot quote me a shipping price until they know what is ordered. They go by weight. I will then have to divide that by the number of people and add that into your total.
I do not really need to order any bits, I got my metric set before I talked to them about the group buy. If these terms are not going to be acceptable please let me know and I will not do the buy.
IPD_Mrs
Zionsville, Indiana
Any way you do it will be fine with me. People will either do it or they won't, a deal is a deal. Let me a give you a suggestion. List out all of the sizes of drill bits with the 35% off price. As people place their orders give a column for total pieces ordered. Once it hits the quantity needed for the discount, clear out the quantity ordered column for that item and start fresh. When you get close to the cut off date for ordering, all of the bits that are short lets people know they may not get them if the order quantity is not hit. Some people will order extras for spares.
Anyway just a suggestion so people will now what they are paying up front and there wont be all that fluctuation in the prices.
