Demo for next meeting - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Local Chapters > South Louisiana PenTurners
  Forgot Password
Reply
Old 08-13-2015, 07:18 AM   #1 (permalink)
Sabaharr's Avatar
Photos: 2
Default Demo for next meeting
I haven't seen any meeting notices recently but if someone can tell me when the next one is I would be happy to do a demo on casting PR pen blanks complete with vacuum degassing. I can also demonstrate how to build a vacuum chamber for about $25 instead of paying hundreds of dollars for one. Just let me know something plenty in advance so I can arrange my schedule. I can also demonstrate doing inlay pen blanks or stabilizing wood with a vacuum chamber and heat activated resin. Just let me know, I love to share knowledge and teach.
__________________
Life is like being on a dog sled team, if you are not the lead dog the view is always the same.
Sabaharr is offline   Reply With Quote Top
Old 11-15-2015, 09:49 AM   #2 (permalink)
wob50's Avatar
Photos: 0
Default
That is something I would go to the meeting for..any luck on getting the
info your looking for. I think the meetings
are the first Sat of the month..but I think..
wob50 is offline   Reply With Quote Top
Old 11-15-2015, 10:54 AM   #3 (permalink)
Photos: 1
Default
I'm a little far from Louisiana, but would. Like to here more n the vacuum chamber
__________________
John
Carbide turning tools and replacement inserts.
www.ncwoodturningtools.com
or
find me in the Vendors Forum.
http://www.penturners.org/forum/f389/
hanau is online now   Reply With Quote Top
Advertisement
Old 11-15-2015, 12:52 PM   #4 (permalink)
Sabaharr's Avatar
Photos: 2
Default
Looks like there is no interest for the meeting but I can answer any questions about the vacuum chamber construction. To start off I got a cylindrical acrylic vase from Michaels about 18" tall and 5" across. I took a scrap piece of pelxliglass 1/2" thick (sure 1/4 would be fine) for a lid and drilled it for a Tee fitting then set a gasket under it. I tapped the threads in that hole and screwed in the fitting. On the Tee I attached a ball valve on one side and a hose nipple on the other. (Later I added a gauge but its not needed). All you need to do then is run a hose to your vacuum pump and you are in business. This one will pull vacuum down to bury the needle at 30. It will easily do 12 pen blanks or 4 duck call blanks at a time. The extra height gives the foam some place to dissipate but I still have to do partial vacuum for a few minutes or it will foam over and run into the hose. I am now looking for an acrylic canister with the lid that locks with a wire mechanism to try to build another one so the lid will seal better. Mine pulls a great vacuum but the gasket does not seal enough to hold it for very long.
__________________
Old 11-15-2015, 12:56 PM   #5 (permalink)
Photos: 1
Default
Thanks for the info. Good description on building it.
So you have picture of your setup?
__________________
John
or
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
