| Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here. |
Welcome to penturners.org!You've found the home of The International Association of Penturners. You are currently viewing our site as a guest, which gives you limited access to view discussions, photos, and library articles.Consider joining our community today. You'll have full access to all of our content, be able to enter our contests, find local chapters near you, and post your questions and share your experience with our members all over the world. Membership is completely free!! If you have any problems with the registration process or your account login, please contact us. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Photos:
Hello, on you tube is a video on how to sharpen a bandsaw blade with a dremel tool and cut off blade. Its fast and works great I have sharpened the same blade 3 times now and its almost like new. Check it out this will save a ton of money for you guys like me who use the bandsaw everyday. Not great for high tooth count, but I use 3-4 TPI a lot. I hope the link works, i have never tried to link anything to a post. Good Luck, Victor
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/-AnDvUqe1Ac&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/-AnDvUqe1Ac&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
__________________
http://landfilllumber.com/
http://stores.ebay.com/landfilllumber A rich person is not one who has the most but the one who needs the least. \"Keep Tree-Cycling\" |
#2 (permalink) |
Photos:
Thanks for sharing....
I'll give it a try.
__________________
Marc Fish - Upstate NY
AAW #27467 exp 12/31/14 ********************** 2012 Birthday Bash Trivia Winner 2x ![]() 2011 Birthday Bash "Losers" Drawing Winner |
#4 (permalink) | |
Quote:
I've been sharpening my bandsaw blade with Dremel but in a different way. I'll try this style next time.
__________________
Dario
![]() Austin, TX USA "Pictures in your mind are memories" - Kathryn O., 3.5 years old |
#5 (permalink) |
Photos:
I can do a 93-1/2" 4 TPI blade in ten minutes and have only used this method a few times. As I said its not for a high tooth count. It does work really well, and you can sharpen as fast as he does in the video with goo results. Its worth a try before you drop another $10-$25 on a new blade. Victor
__________________
#6 (permalink) |
I wonder how that method would affect the tracking and drift of a blade? I have a smaller blade on my saw that drifts bad to one side becasue it accidently hit a steel guide block because I forgot to move the thrust bearing forward when swapping out a wider blade one day. It's a fine tooth, but might still be worth giving it a shot to see how it works. It was a great blade for scrolls.
__________________
#8 (permalink) | |
Quote:
__________________
Dario
#10 (permalink) |
Tried it this morning and worked great.
One note...make sure you make grinds as even as possible on all the teeth. Obvious but if not done, the longer/protruding teeth will be very grabby. The sharpened blade cuts like new except the grabby part. Tested it on TX Ebony and it didn't complain a bit. Sharpening my 72" (3 tpi) blade took about 5 minutes. Surely worth my time and maybe I'll get better and faster in time. I sure will use this style of sharpening now. BTW, I used a Dremel with what I believe is 180 grit diamond lapidary bit.
__________________
Dario
| Bookmarks |
| Thread Tools | |
| Display Modes | |
