what is the use of these....
penmanship
Winnipeg, Manitoba
Are they only for shipping/protecting the nib assembly, or do they have another purpose.......? I have only made a few hundred pen's & never really gave them another thought.
TIA,
Tim
Turned Around
Houston, TX
oh, i just had to use one of those for a cigar fountain pen earlier. the set i had, uses it for a tension type hold on the cap. not a screw cap, but it's just pressed on and it kinda hugs the nib.
ed4copies
Local Chapter Manager
Racine, WI, USA.
Pics won't do you any good.
The piece goes into cap (screws on a post that comes off the clip holding piece) and serves to hold the cap on the pen. When properly placed, you can't see it.
Turned Around
Houston, TX
that is true. but be careful, they crack easily. and if it cracks, it won't grip the nib. and be careful with the assmebly itself, if put in too far, it won't catch the nib and the cap just falls off. which reminds me, i need another one.... haha
DonWood
Chambersburg, PA, USA.
Does anybody know where you can purchase some of these. I have cracked some during assemble and need some replacements. Appreciate any info you have.
Don
lorbay
BC. Canada
Don
Oh man, I have never botherd using these and I just threw 6 out. I will keep them from now on and publish when I have a few. Sorry
Lin.
penmanship
Winnipeg, Manitoba
:eek: i also threw about about 15 or so that i've collected......(for no reason until now)
I'll hang on to them, and put them out there when I have some....
Don
ed4copies
Racine, WI, USA.
Don
Lin.
You should NOT use them, unless you are making a "pull apart" design rollerball or fountain pen.
You don't use them with a twist off cap design
