Whale Bone
bruce119
Franklin, NC, USA.
I have a TON of whale and matinee bone from Florida. Now my question is if they got it in Florida where about....It is most certainly fossilized and then solid stone. The bone I have mostly came from bone valley the Peace River and Phosphate mines.
The fossils I have are solid like a sand stone (no pores) modern bone would have pores and I don't think your going to dig up modern wale bone in Florida.
Any photos????
Try drilling a hole in a piece and see how it goes....
awood6971
High Springs, Florida
I recently purchased a piece of whale bone and sealed the sides and ends with CA making it like a trough. Then I flooded it with CA and let it set. In some sense it is like stabilizing it. That said...I have worked with Bone before. This will be the first time I have turned it though. For good measures I am going to paint my tubes White and or reverse paint the inside of it once drilled. Bone is a nice media to work with, just note that it does have a distinct smell and it doesn't set well with some people. Also...regardless of what you do to prep the blank, make sure to wear a dust mask!!! You do not want bone dust infiltrating your lungs! Hope this Helps. Happy Turning.
bruce119
Franklin, NC, USA.
Hi all, my question is has anyone ever used whale bone? While
In fl my parents neighbor works construction and dug up a lot of whale bone, so I thought that might be cool stabilized. Thanks for any info :cool:
Neil, What color is the bone...that will tell a lot....
Allen, I see you are in High Springs...been there many times and dove the Santa Fe River for fossils. It is very rich in Mastodon, Dugong (matinee) and more All (most) the fossil material I have fond was black....Now in the Phosphate mines of Bone Valley (the Peace River basin) can be a white blond color...
Just wondering if were talking fossils or modern bone???
Donovan
South Africa Walkerville
I bought a whale rib bone a few months ago. It is more than 2 meters long. It is from a whale that beached it self in 2003. I turned some but it still felt as if it was wet. Was not to difficult to turn. It is not much to look at. I want to stabilize it with a color and try again
Donovan
Pitoon
Vicenza, Italy
Donovan
bone is similar to wood in the sense that it needs to dry out to a certain moisture content.
Pitoon
rd_ab_penman
Red Deer, Alberta, Canada.
Cuts and turns like antler.
Les
