| Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here. |
Welcome to penturners.org!You've found the home of The International Association of Penturners. You are currently viewing our site as a guest, which gives you limited access to view discussions, photos, and library articles.Consider joining our community today. You'll have full access to all of our content, be able to enter our contests, find local chapters near you, and post your questions and share your experience with our members all over the world. Membership is completely free!! If you have any problems with the registration process or your account login, please contact us. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) | |
Here's a tip that will save you some headaches. Make sure to shoot some accelerator down the inside of your blank before you insert the tube if you glue up with CA. You can spin the blank and even do a little back and forth pushing to evenly distribute the glue before it sets up if you use thick CA.
Why accelerate the blank? Well the reason is that CA usually gets the curing process started by grabbing some moisture from the blank when you do a wooden pen. Even a dry blank has 7-9% moisture which is enough to trigger the curing of the CA. An acrylic blank has ZERO moisture unless you put it there. It's possible to have the ends cure from moisture in the air but the center of the blank is still liguid CA trapped that might as well be in the CA container. Sometimes the blank will spin if enough force is applied to shear the small amount that actually has cured. Moistening the inside with accelerator solves this problem. All the CA cures and you get a nice strong bond. ![]() ![]()
__________________
Stay safe out there!
Bree What a long strange trip it's been! The 60's will never leave, if we refuse to leave them!! |
#2 (permalink) |
Interesting idea. My fear would be the ca setting up before I got the tube seated properly. I'm certainly game to giving it a try though
.Thanks for the tip. Carl
__________________
It is better to let people think you are an IDIOT than to open your mouth and prove it
#6 (permalink) | |
Local Chapter Manager
Quote:
2) Don't glue while the blank is still hot from drilling. 3) If you use fluid to keep the blank cool while drilling, remember water will accelerate the curing process (it can make medium set up while trying to spread the glue--slide in the tube) If you follow these hints, in ten years of making pens I had about three set before I was ready. ![]()
__________________
Ed Brown - ZipIt--to help build chapters (click for explanation)
![]() "Often copied....NEVER duplicated!!!" Now offering Berea Baron and Sedona pens!! click on blue to see what's NEW "If you have not visited today, you missed new products!"![]() |
#7 (permalink) | |
I use the thick CA and have found that if the tube to drilled hole fit is tight, you will have issues if you dilly dally. Cyanoacrylate dries in the absence of oxygen. Don't believe it, put some on a couple of tight fitting pieces of anything and press it together and you don't have time to blink before they're stuck. On your fingers the moisture adds to the speed of irretrievable stuckness. If you find the tube is stuck half way in, simply use a fine tooth coping saw to remover the protrusion and insert it in the other end of the blank with some CA on it and the issue is solved.
WB
__________________
Is that your first answer or your best answer?
#8 (permalink) |
I totally agree with WB. Considering that usually the press-fitted mechanism parts only use a small amount of each end to secure themselves, the cut-off and insert to the other end works just about every time. I have rescued several work-ups that way before I learned better ways to glue up.
__________________
***Bill***
Life without God is like an unsharpened pencil...It has no point! "Some people spend their life wondering if they made a difference. Marines don't have that problem." R Reagan |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
