Spectraply turners...Please read
Herb G
Southern Maryland
Does Spectraply need to be stabilized before turning?
Or is it ok to turn as is, with carbide tipped tools?
I'm looking to turn some bottle stoppers & maybe a pepper mill or two.
Thanks for any help.
I've only used it for pens, rough with carbide and finish with HSS skew. I can't speak for others, but for me the scraping with a skew keeps me from having to sand--and avoids the sanding dust bleed-over that I got on the first few I did.
earl
earl
The nice thing about Dymondwood is there is no sanding dust bleed-over.
I really like using SpectraPly and turn it with carbide tools. I like it enough that I bought a box of 100 assorted pen blanks a while back. After sanding I make sure the blank is very clean with DNA. I then put on a couple of liberal coats of medium CA to make sure all the pores are sealed.
Tomas
Tomas
Before or after it's turned?
Herb, if he stated after sanding, it would indicate he meant after turning. Who would sand their blanks and apply CA glue, before turning them??????
Len
I use it for pens and bottle stoppers. Turn to final size and shape. Then seal with 1-2 light coats of thin CA and sand to at least 400 grit. Finally apply a CA finish and polish.
Mine is soft, but all turned with HSS..I can't see carbide being a problem. It is something that i finish with CA even though it is a laminate. LarryC's Dymondwood is a solid as a rock. In fact, my pen plus finish looks more like CA on. here is a pic. The Dymonwood is more two-tone too - unlike the spectraply, which is what make the spectraply interesting.
Tomas
Although I have been know to do some strange things, this isn't one of them. My process is to sand with Abranet up to 600. Then I wipe the turned blank thoroughly with DNA. I put on a couple of liberal coats of medium CA making sure that the "pores" are all filled. I finish it with 16-20 coats of medium CA and wet sand using all 9 colors of MicroMesh.
Tomas
Herb, my experience with Spectraply is limited to pens and handles for bottle openers and coffee scoops.
Here's my short answer: stabilizing Spectraply isn't necessary and has little benefit.
I came to that conclusion after performing a highly subjective test. Regrettably, I don't have pictures to illustrate.
I chose 2 x 14 different colors of Spectraply (i.e., 28 blanks). I stabilized one set of the colors, and left the other set of colors "raw". Then I made 28 pens (slimline or trimline). I used the same component type and plating for each color pair, so that type and plating wouldn't interfere with a visual comparison.
I used a skew for all pens, sanded to final fit using the same process, and finished all the same (walnut oil after final sand, CA finish, micromesh through all grits, buffed before assembly.
Observations (again, subjective)
-Stabilizing caused darker colors (blacks, blues, purples) to bleed, which appeared to slightly muddy brighter colors (yellows, light greens, whites, and no dye). It wasn't a severe change, but I could detect it on the margins of the layers.
-I observed more what I'm calling "micro tear out/fuzziness with stabilizing than without. That surprised me, because I expected the opposite. Even with a sharp skew, this meant for stabilized Spectraply I had to turn more proud of final diameter and sand more to final diameter.
-I didn't have any problems with either stabilized, or non-stabilized delaminating when a layer approached micro-thin.
-Non-stabilized had more sanding dust stick in the pores, but a puffer bulb and liberal use of denatured alcohol took care of that.
-After final sanding, applying oil, CA finish, final sanding, and buffing, non-stabilized looks brighter and margins of the layers were more sharply defined (not muted/muddied/color bled)
-After about 6 months of not looking at the color pairs, I pulled them out to see whether I could still tell a difference. I can.
-Stabilizing risks color bleed of dark into light/bright. It's not severe, but it's enough to notice.
-I won't stabilize Spectraply going forward. I think it's neither helpful, nor harmful. It adds unnecessary steps and cost (time and stabilizing resin), and yields a turned item that the casual observer wouldn't notice is different from a non-stabilized item.
