Snugging Up Barrel ID - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
  Forgot Password
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 01-13-2019, 12:36 AM   #1 (permalink)
Photos: 0
Default Snugging Up Barrel ID
Last week I had a problem with Epoxy inside some barrels, well I use round files and cleaned them up to where the trimmer bushings were a snug fit.
I finish one pen yesterday and it was OK, but today I finished a 2nd Tycoon and it felt snug when pressing the inserts in BUT. after unscrewing and screwing the cap on both ends one of the inserts popped out and I lost the spring
So my question is can I paint a thin layer of epoxy inside the end of the barrel and let it dry and then press it back together or just epoxy the insert in?
Thanks.
super8mm is offline   Reply With Quote Top
Old 01-13-2019, 07:00 AM   #2 (permalink)
randyrls's Avatar
Photos: 67
Default
Steve; You can use epoxy to glue the insert. This is important: Put the glue on the inside of the tube, NOT on the fitting. If you are pressing the fitting, spread the glue around the inside of the tube.
On some delicate materials I expand the tube end so it is a slip fit on the fittings.
I use a dab of thick CA (aka superglue) on the inside of the tube and give the fitting a twist as I insert it.
__________________
Randy S.
~~~~ Add Your Postal Code and Country to the UserCP ~~~~~
Practice random kindness and commit senseless acts of beauty.
randyrls is offline   Reply With Quote Top
Old 01-13-2019, 07:30 AM   #3 (permalink)
Group Buy Coordinator
Monty's Avatar
Photos: 13
Default
I like to use a drop of red locktite to glue loose a fitting piece in, it's not as messy as epoxy and does not out gas like CA.
__________________
Mannie - Pearland, TX
I hate it when people steal my ideas before I think of them.
Monty is offline   Reply With Quote Top
Advertisement
Old 01-13-2019, 09:40 AM   #4 (permalink)
Photos: 0
Default
Quote:
Plus - a heat gun can be used to break the Loctite bond.
larryc is offline   Reply With Quote Top
Old 01-13-2019, 01:06 PM   #5 (permalink)
Photos: 0
Default
Thanks guys, all good ideas, I will give them a try
Old 01-13-2019, 01:39 PM   #6 (permalink)
Photos: 4
Default
Quote:
Red Loctite requires heat in excess of what a pen blank would withstand to break the bond. It's something around 550 degrees.
__________________
-John-
Terredax is offline   Reply With Quote Top
Old 01-13-2019, 06:25 PM   #7 (permalink)
Photos: 0
Default
I don't know what the specs are but I have not found that to be the case where I have used it.
Old 01-13-2019, 07:22 PM   #8 (permalink)
Photos: 0
Default
I looked it up and this is what I found
NOT RECOMMENDED FOR:
Use on plastic parts, particularly thermoplastic materials where stress cracking of the plastic
could result.
Use in pure oxygen and/or oxygen rich systems and should not be selected as a sealant for
chlorine or other strong oxidizing materials
and they say it is removable once cured by heating up parts to 500F (260C).
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
