Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 10-24-2008, 01:17 AM   #1 (permalink)
Photos: 40
Wink Sierra Pens Tubes.
I have found that using a 10.5mm drill bit makes a much better fit than using the 27/64 drill bit that they recomend much better fit, to much slop.
__________________
Mather323 is offline   Reply With Quote Top
Old 10-24-2008, 04:46 AM   #2 (permalink)
Mack C.'s Avatar
Photos: 110
Default
Quote:
Originally Posted by Mather323 View Post
I have found that using a 10.5mm drill bit makes a much better fit than using the 27/67 drill bit that they recomend much better fit, to much slop.
Hi Mather; I assume you meant to say 27/64 drill bit. I don't recall having a problem with my Sierras, but there could be some merit to your suggestion since the 10.5 mm bit is about 8½ thou. smaller.
Are 10.5 mm bits readily available?
__________________
Mack C. in Brooklin ON
It feels great to sell a pen;
It feels even greater to give one to a friend!
I am a proud supporter of
"Pens for Canadian Peacekeepers"!
477 kms from my daughter in Milford MI.
Mack C. is offline   Reply With Quote Top
Old 10-24-2008, 04:49 AM   #3 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
On a few pens I have used the 10.5 but I usually go back to the 27/64. The 10.5 is too tight in some cases - I have drilled a 10.5 hole is some blanks and the fit was so tight for some reason that the tube was difficult to get in. In cases like this, it means that there will be too little space for glue as glue will be pushed out, or the glue will end up inside the tube.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Advertisement
Old 10-24-2008, 07:14 AM   #4 (permalink)
Photos: 40
Default
It could be the big bench top drill press that my dad bought at the state fair years ago, I am sure that he did not pay over $5 dollars for it. Ha Ha I have noticed that when drilling the acrylics and acrylesters that I have seen the biggest difference. Both drill bits are colts, I guess that I could even have a bad bit, since the 10.5mm drills so nice and the 27/64 looks like a hog walked thru it when I am done drilling. Any recomendiations for a new drill press? I found the 10.5mm drill bit at Craft Supply USA for $14 dollars. Mike
__________________
Old 10-24-2008, 07:23 AM   #5 (permalink)
Mack C.'s Avatar
Photos: 110
Default
[quote=Mather323;752236]
Hi Mike; I think the big question is what's your budget. Floor model or bench top?
I've got a Delta Model 17-901 floor type that has served me for years. I do all of my blank drilling on the lathe now!
__________________
Old 10-24-2008, 08:08 AM   #6 (permalink)
randyrls's Avatar
Photos: 47
Default
Quote:
To join the thread; 10.5 drill bits are commonly available in metric sets that go from 3mm to 13mm in .5 mm steps.
Hank; I prefer to drill my blanks with a snug, just sliding fit. I many times use a different drill bit than the one recommended.
Twist drill bits have a tendency to "unwind" and drill a hole from .001 to .005 larger or smaller depending on the material, drilling speed, and whether you are enlarging a hole or drilling a hole in one go.
This is only my opinion and understand the differences will be less than ten thousandths inch.
Wood drills a smaller hole. Acrylic holes will be slightly larger.
Slow speed drills a smaller hole. Faster drills a larger hole.
When enlarging a hole the hole will be smaller than drilling in one go with the same bit.
I use a VS milling machine to drill holes. It is very accurate and drills holes dead on!
__________________
Randy S.
~~~~ Add Your Postal Code to the UserCP ~~~~~
A question asked of Charles Babbage the creator of the Analytical Engine: "Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?" I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question. -- Charles Babbage
randyrls is offline   Reply With Quote Top
Old 10-24-2008, 09:18 AM   #7 (permalink)
Assistant Moderator
Vendor Liaison
maxwell_smart007's Avatar
Location: Lac du Bois - middle of nowhere, in the Great White North
Photos: 0
Default
Seems like too tight of a fit will remove all of hte glue!
__________________
"When it is dark enough, you can see the stars"
"He who can no longer pause to wonder and stand rapt in awe, is as good as dead; his eyes are closed."
maxwell_smart007 is online now   Reply With Quote Top
Old 10-24-2008, 09:58 AM   #8 (permalink)
Photos: 40
Default
Bench Top.
__________________
Old 11-03-2008, 01:22 PM   #9 (permalink)
Photos: 0
Default
I agree 10.5 mm is much more accurate!! Big difference in size!!
Grub32
grub32 is offline   Reply With Quote Top
Old 11-03-2008, 01:48 PM   #10 (permalink)
JimB's Avatar
Photos: 0
Default
I found the same problem using the 27/64. I was getting gaps between the wood and tube and some slop. I used a lettered "Z" bit from my HF set on my last 5 Sierras without any problems. I believe both the "Z" and the 10.5mm are .413 inches. It beats spending $14 on one bit.
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
