Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 06-06-2010, 05:14 PM   #1 (permalink)
skiprat's Avatar
Photos: 174
Default Segmenting puzzle
Just for some fun, see if you can figure out how to cut this segmented blank.
When the blank is in the square, the red points reach the end of the blank.
The yellow points reach about 2/3 of the way to the other end.
But once the blank is turned round the length of the red and yellow blanks are the same. The point of the yellows don't move.
I'm busy building this blank now, but it's too late to continue or my neighbours would shoot me ( unless my wife did it first !!)
This one can easily be done with a table saw, but mine has wavey diagonals and I'm using a router. Either way, the ends of the blank would look the same and reveal the way it was cut. I just drew it like this because it's difficult to draw wavey lines in MS Paint.
Have a think and post a pic of two squares with the way you believe the ends would look
Edit;; The ends of the points MUST remain sharp and not become rounded once turned!!!
__________________
skiprat is offline   Reply With Quote Top
Old 06-06-2010, 05:33 PM   #2 (permalink)
Photos: 0
Default
traditional archers make these all the time when footing wooden arrows, i am told there is a jig available for doing it which uses a router, i am sure a google search could turn up more info
it would probably be called a four footing jig
the big difference is the archers do it on round stock to start off with
the main reason for doing this to arrows is to put a heavier, harder piece of wood at the front of the arrow, but the joint has to be very strong to take the impact
hope this helps
MIK
MIKL is offline   Reply With Quote Top
Old 06-06-2010, 05:54 PM   #3 (permalink)
skiprat's Avatar
Photos: 174
Default
Hi Mik, welcome to the IAP
I don't doubt you for a second that there is a snazzy tool/ jig out there to do such a cut.
But most of us only have basic stuff like bandsaws and table saws and maybe a router ( and lathes of course)
Can your gadget ( please find a pic if you can, thanks) do wavey lines?
Here's a pic of my router template that I knocked up with a piece of clear polycarb, 8 screws, and a bit of MDF. I just glued a strip of aluminium along the edge to make sure it was smooth.
__________________
Advertisement
Old 06-06-2010, 06:28 PM   #4 (permalink)
skiprat's Avatar
Photos: 174
Default
I found some pics of a footing jig that Mik referred to. ( I think )
It looks very interesting and not too difficult to make. The jig looks like it would make the pale wood cuts and from what I gather, the dark wood is two pieces, each with a split. I couldn't find a jig to do those bits but I guess you could use a bandsaw. I don't know how sharp the edges and points would be.
Thanks for jumping in Mik, I'm gonna do some more googling and maybe copy one of them.
LOL, see if you can find a similar jig to do the wavy cuts
__________________
Old 06-06-2010, 08:20 PM   #5 (permalink)
jthompson1995's Avatar
Photos: 2
Default
That is a four footing jig you found but the dark wood is not two pieces, but one with kerfs cut in at 90 degrees to each other. The light wood is inserted into the kerfs and the dark wood is wedged outward and the whole thing is clamped and glued. This is a pretty common way to fix broken arrows or add some additional weight to the tip of the arrow for more durability and/or better penetration and flight.
I have not seen wavy lines done but I have seen spiraled designs, made by heating and twisting the arrow.
__________________
Jason Thompson - Parkville, MD
A man who works with his hands is a laborer, a man who works with his hands and his mind is a craftsman, but a man who works with his hands, his mind and his heart is an artist. - Louis Nizer (1902-1994)
jthompson1995 is offline   Reply With Quote Top
Old 06-06-2010, 08:30 PM   #6 (permalink)
BRobbins629's Avatar
Photos: 47
Default
Quote:
So do we have to wait 9 months for the outcome?
__________________
Bruce
BRobbins629 is offline   Reply With Quote Top
Old 06-06-2010, 08:35 PM   #7 (permalink)
Photos: 25
Default
Quote:
__________________
-Dan Horowitz
witz1976 is offline   Reply With Quote Top
Old 06-07-2010, 12:41 AM   #8 (permalink)
skiprat's Avatar
Photos: 174
Default
Quote:
Originally Posted by jthompson1995 View Post
That is a four footing jig you found but the dark wood is not two pieces, but one with kerfs cut in at 90 degrees to each other. .
Thanks Jason. I found a pic. It looks simple enough to do using these archers methods. I wonder if pool que's can or are done like that?
Thanks you guys
LOL
__________________
Old 06-07-2010, 02:23 AM   #9 (permalink)
jjt
Photos: 0
Default
hi,
I am a french turner and I do not speak English, so I go through a translator.
I found this:
http://www.supreme.fr/fabqueue.html
jean-Jacques
jjt is offline   Reply With Quote Top
Old 06-07-2010, 02:58 AM   #10 (permalink)
skiprat's Avatar
Photos: 174
Default
Welcome!!! Thank you for that great link Jean-Jacques. I can't speak French but if you go to the bottom of that page and click on 'Cherger le Pdf' then it gives a much bigger document ( as a Pdf )
I'm really pleased that a couple of new guys have joined in here. I'm sure we can learn something from you guys.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
