thewishman
I've been making these for a couple of months and tell people that they can roll up a $100 bill and hide it away. The trouble is, the bottom of the bill gets hung up on the pressed in cap. That makes it hard to work the bill in and it is frustrating.
I put the bottom cap into a 13-14mm collet and turn the lathe on reverse. I taper the inside of the cap to get rid of the hard, straight edge. The cutting is done to the far side, inside. (I could do it with the lathe in forward cutting the near inside, but then I couldn't see what I'm doing.)
The process takes just a few seconds and you can do a bunch in a few minutes.
