Sanding belt cleaner - tip
RegisG
Mount Juliet, Tn
I know that the rolls/strips of sanding belts we use for pen making are not very expensive. But, you can get 3, 4 or 5 times the life out of them if you simply buy a sanding belt cleaner for about $6 or $7.
I keep one right on my lathe bench when sanding. A few swipes after every use and you're done. Lot faster than cutting new piece every time you turn around, and they last forever. Probably have had this one for 20-30 years.
Then, again, maybe everyone already uses one but, thought I'd post anyways!
I have overdone these strips though.
Regis
chartle
Pgh, PA
I use abranet never clogs. Though I do have one of those sticks I bought over 25 years ago.
SteveG
Eugene, Oregon 97404
The 'Eraser' is fairly large. I have cut mine in half, for use at multiple shop locations. (Hint: NOT a good idea to cut on the band saw...tends to grab. Razor knife will do the job.)
tomtedesco
Centennial, CO
A friend of mine showed me a tip using a piece of indoor/outdoor carpet. I have a 6in X6in piece on my bench next to the lathe and as paper gets loaded a quick swipe across the carpet cleans the sand paper.
RegisG
Mount Juliet, Tn
That's sure easy to try and sounds like it works.
Regis
Use them all the time and I like the large ones because of my drum sander and belt sander. I just used one on a belt sander a couple minutes ago after I sanded a blank I made today and needed to square it. They are cheap enough and last a long time.
