Rounding Blanks??
Hugob
Pretoria, Gauteng, South Africa.
I've always battled a little bit in the first face of turning blanks. The part were your blanks still have 'squared corners'....
I was wondering if anybody got a different way than turning this with a 'gouge'. What about a 'File' to get the blanks 'round' and then work them the rest of the way with yout favorite gouge.. or maybe 'router' the corners off..
pen-turners
Honolulu, HI, USA.
Hugo,
I have heard of people using a router to do a roundover on the sides before to shorten time to take the blank to round but have never seemed to need to myself.
Are your tools sharp???? I used to experience quite a bit of chatter when roughing my blanks until I found out how to sharpen correctly. Now I actually enjoy roughing out my blanks....
It should not be a battle for you if your tools are sharp and you have the correct angle as you are cutting.
Chris
Old Griz
Passed Away Oct 4, 2013
Hagerstown, MD, USA.
I don't use a gouge at all on my pens... I start by taking a planing cut with my skew.. works like a dream and leaves a much better finish...
If you can get Alan Lancer's videos on using the skew he demonstrates the technique better than I can describe... it is where I learned to do it..
Gary Max
Southern Kentucky
Use a stationary sander to remove the unwanted material.
Just sand the corners off one at a time.
I do wear a good pair of gloves---sanding something this small can get hard on fingertips.
I use this for some Acrylics that are very hard and oversized.
its_virgil
Wichita Falls, TX, USA.
Like Tom, I never use a gouge on a pen. I start and finish with a skew. I rough turn with a 1.5" oval skew and end with a .75" or a 1" skew. The heavier skews seem to give a smoother cut than the smaller ones. More mass I suppose, but they don't seem to bounce as much....Love the skew!
Do a good turn daily!
Don
Originally posted by Hugob
<br />I've always battled a little bit in the first face of turning blanks. The part were your blanks still have 'squared corners'....
ctEaglesc
Passed Away Jul 4, 2008
Camden, S.C., USA.
IF the wood is prone to tearing out, such a piece cut on the bias or cross cut I'll use the bandsaw sled.It's a little faster than sanding.
I have a tendency to over sand one end or the other.
I'll do the same thing with antler if it is a very dense section.
(You kind of get the hang of identifying it.)
I have custom ground my tools(Ahh the beauty of a 12 piece $10.00 set from HF)and use a small gouge with sharp"ends or edges" and kind of "snow plow" from one end to the other.
Any good SHARP tool should work.Love that diamond stone!
(Please excuse the techincal terminology)
Another technique I have started doing with antler is to rough turn between centers due to it's odd ball shapes,
I use a collet to drill them on the lathe but also use a "V" block on the DP.
The neat thing is your center is already marked.Just make sure you have turned a straight cylinder.
It helps to have a "Steb center" for the live end.
ctEaglesc
Camden, S.C., USA.
Originally posted by Gary Max
<br />Use a stationary sander to remove the unwanted material.
You might try adapting the method I use for roughing the tubes to save your fingers.
After you have glued and milled the blanks with the tubes in tehm
Slip a long handled screw driver( you might need a spacer) in the tube and angle it into the drive direction of the belt.
You should be able to hold the top "corner of the blank to keep it steady.
No more power manicures!
elody21
I like to use a table top belt sander to round off the edges. Works great and is fast!
Hugob
THANKS ALOT for all the GOOD advice...
I'll read it again, so that it can sink in a bit......
I'll think going with the beltsander idea will work for me.
I've put times down for all processes of making pens, and find that the turning part is my biggest bottle neck. That's why I'm trying to find a way to turn my blanks quicker.
woodscavenger
Boise, ID, USA.
Excuse my ignorance, but I must not understand the issue. I Haven't timed it, but it only takes about a minute to round out a blank with a skew or a gouge in my shop. I am a little agressive but have not had any blow outs at this point in time. If I tried bandsawing or sanding all four sides on every blank I would go nuts. Just MHO.
goldentouch
Wills Point, Texas, USA.
I use a 1/2 inch gouge I put a longer grind on that I use until I get down to the final cut then switch to the skew. It takes me less than a minute to round the blank with the gouge. I cut from the outside in and this will help keep blow out down. I use this on all burl. So far no problems.
Rifleman1776
Mountain Home, Arkansas, USA.
Originally posted by woodscavenger
<br />Excuse my ignorance, but I must not understand the issue. I Haven't timed it, but it only takes about a minute to round out a blank with a skew or a gouge in my shop. I am a little agressive but have not had any blow outs at this point in time. If I tried bandsawing or sanding all four sides on every blank I would go nuts. Just MHO.
Agree. On a little 3/4"X3/4" blank, knocking off the corners with a gouge is only a matter of seconds, and I use a light touch but big (1") spindle gouge. I think many turners are afraid to use high speed at the beginning. For pens, it is top speed from git go, often same for duck calls where I start out with a 2"X2" blank. For me, choice of skew or gouge for remainder of job depends on the wood. Some woods want a skew, others resist.
ctEaglesc
Camden, S.C., USA.
Try turning some blanks cut cross wise rather than with the grain and you will eventually find out why it is sometimes prudent to knock off the corners.
this is a piece of red palm
pen-turners
Honolulu, HI, USA.
Originally posted by cteaglesc
<br />
Many of the woods I turn are cross-cut and unstabilized burls and have never had a problem. Key to success is sharp tools and correct angle of inception to achieve maximum cutting efficiency.
Rifleman1776
<br />
That must be trick photography, palm refuses to turn. Can't be done. [:p] I bought some and it just sneers at me on the lathe while it grinds down my tools. Five seconds, tops, before a tool needs resharpening. I gave away at a club drawing a large hunk. Still have a 2"X2" stick here that my descendants will probably throw away some day in the future. Harder than granite.
Good creative photography, actually looks like a very nice pen....for a pen that can't be turned. [:)]
