Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 12-09-2008, 09:29 PM   #1 (permalink)
CHICAGOHAND's Avatar
Photos: 0
Default RING MAKING
Well I would like to try my luck at making a few rings for the wife and I am having difficulty with a good method of rechucking it after I part it off. Does anyone have any other tips for me besides this link.I see some great wood rings out on the net but I have not been able to figure out the secret method.
http://www.woodturningonline.com/Tur...wood-ring.html
__________________
Very few other professions require you do most of your best work in the dark with the power off.
http://www.anamericanwoodworker.zoomshare.com/0.html
CHICAGOHAND is offline   Reply With Quote Top
Old 12-09-2008, 09:39 PM   #2 (permalink)
Skye's Avatar
Photos: 9
Default
I don't know if you picked up on it or not but the guy finished the inside, parted it off, then slid it on a tenon on the waste block. It's just pressure fit into place. I've done one before just playing around and there's an art to it for sure.
__________________
Ok, first of all; I'm not 100% in love with your tone right now.
Skye is offline   Reply With Quote Top
Old 12-09-2008, 09:44 PM   #3 (permalink)
BRobbins629's Avatar
Photos: 47
Default
I haven't done rings, but I have done a few centerbands by making some bushings with very narrow tenons and just mounting on a pen mandrel. Works for me.
__________________
Bruce
BRobbins629 is online now   Reply With Quote Top
Advertisement
Old 12-09-2008, 09:45 PM   #4 (permalink)
ldb2000's Avatar
Photos: 240
Default
That link is a wealth of knowledge for making rings . He uses a jam chuck to hold the parted ring for finishing , pictures 9 and 10 on the second page . This is the only way I know of to this . I guess you could use the step jaws on your chuck .
That is a great idea Bruce , I never would have thought of that .
__________________
Butch
Kitless Fanatic
The simplest method is usually the best solution (Me )
Any fool can know , the point is to understand (Albert Einstein)
There are no mistakes....Only happy accidents (Bob Ross)
http://www.penmakersguild.com/images.../logosmall.jpg
ldb2000 is offline   Reply With Quote Top
Old 12-09-2008, 10:22 PM   #5 (permalink)
Photos: 0
Default
I just found these on youtube.
http://www.youtube.com/watch?v=CZbswhEzOmo&NR=1
__________________
Old 12-10-2008, 07:29 AM   #6 (permalink)
btboone's Avatar
Photos: 2
Default
I do mine from a solid block glued up from 3 pieces, and turn the outside first, followed by the inside and part it off. I use an expanding aluminum mandrel to grip on the ring to finish the inner corner for side 2. A tapered scrap of wood can work well there too.
__________________
Bruce Boone
Boone Titanium Rings
Roswell, GA
www.boonerings.com
btboone is offline   Reply With Quote Top
Old 12-10-2008, 08:16 AM   #7 (permalink)
devowoodworking's Avatar
Photos: 23
Question
Quote:
I've always been curious how you make the ones with the inlaid wood Don't answer if you don't want to give out any trade secrets
__________________
devowoodworking is offline   Reply With Quote Top
Old 12-10-2008, 08:22 AM   #8 (permalink)
bad
Photos: 0
Default
Bruce, those are amazing rings. When I get time after Christmas I'll have to give that a try. I doubt if they'll be as nice as yours. At least not at first ; )
__________________
Bruce Deeks
In woodturning there are no mistakes, just design opportunities.
bad is offline   Reply With Quote Top
Old 12-10-2008, 08:26 AM   #9 (permalink)
Skye's Avatar
Photos: 9
Default
Dang man, what do you finish those with?
__________________
Old 12-10-2008, 09:24 AM   #10 (permalink)
btboone's Avatar
Photos: 2
Default
I do a CA finish. I sand them with a drywall sponge, maybe 220 grit then a fine yellow sanding sponge, probably around 320 grit and polish from there. When I sand, I don't spin them on the lathe. I sand at a 45 degree angle, and that does a better job of smoothing the surface. The metal rings with the inlay are done by a proprietary method that I came up with. I'll keep those a secret.
__________________
Bruce Boone
Roswell, GA
www.boonerings.com
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
