Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 07-26-2007, 12:32 PM   #1 (permalink)
Randy_'s Avatar
Photos: 34
Default Rewiring a JET Mini VS To Run Backward
I remember seeing an article/tutorial that showed how to rewire a JET VS so it would run backward. Running backward makes for better sanding results.
Not sure whether I saw it here or somewhere else? Anyone out there who can help me find this article??
Thanks!!
__________________
Randy_ is offline   Reply With Quote Top
Old 07-26-2007, 12:38 PM   #2 (permalink)
Local Chapter Manager
ed4copies's Avatar
Photos: 21
Default
Randy,
You probably already thought of this, but if you turn the lathe around, then plug it into an "outlet strip" with a switch on it, you can turn it off and on with that switch and it is running away from you - so you can sand. (If this is a semi-permanent use of this lathe, it is much easier than rewiring).
__________________
Ed Brown - ZipIt--to help build chapters (click for explanation)
"Often copied....NEVER duplicated!!!"
Now offering Berea Baron and Sedona pens!!
click on blue to see what's NEW
"If you have not visited today, you missed new products!"
ed4copies is offline   Reply With Quote Top
Old 07-26-2007, 12:52 PM   #3 (permalink)
Photos: 0
Default
Randy,
I think the article you are looking for is in pdf format and is available here:
http://www.FrontRangeWoodturners.com/howto.html
__________________
[8D]~JimM~[8D]
JimM is offline   Reply With Quote Top
Advertisement
Old 07-26-2007, 01:56 PM   #4 (permalink)
Randy_'s Avatar
Photos: 34
Default
Another one of your practical jokes, Ed, or are you just confused??;)
__________________
Old 07-26-2007, 02:10 PM   #5 (permalink)
Randy_'s Avatar
Photos: 34
Default
That is the information I was looking for. Think I may have seen it in a different form; but that is exactly what I needed.
__________________
Old 07-26-2007, 02:53 PM   #6 (permalink)
ed4copies's Avatar
Photos: 21
Default
Quote:
"Confused" is my middle name.
But, if a lathe turns toward you, when you step to the other side (back) it is running "away" from you, as viewed from the top.
Try it, I believe I am correct this time (but I WILL test tonight).:D:D[?][?][?][?][?][?]
__________________
Old 07-26-2007, 02:58 PM   #7 (permalink)
Photos: 0
Default
I don't get it. If you're using a reasonably portable lathe - like the Jet Mini, whty wouldn't it work to just pick up the whole lathe and turn it around so that the headstock is on your right instead of your left? Then the piece on it would be rotating up toward you and that's the point for the increased sanding ability isn't it?
Better yet, have your lathe on a seperate stand, not the workbench, and then just walk around to the otherside of it with your sand paper in hand.
jtate is offline   Reply With Quote Top
Old 07-26-2007, 03:00 PM   #8 (permalink)
ed4copies's Avatar
Photos: 21
Default
If I am wrong, at least now I have company!!!
Thanks Julia!!:D:D:D
__________________
Old 07-26-2007, 03:57 PM   #9 (permalink)
Blind_Squirrel's Avatar
Photos: 12
Default
My Nova DVR XP has forward and reverse on it. I found that the tension nut on the mandrel tends to come loose when you run it in reverse. If you are using the no-mandrel method this problem is eliminated. Also, I am used to having the lathe push from the top and pull from the bottom of the blank. To me it feels weird to pull from the top and push from the bottom.
__________________
-Scott
Chesapeake, Va.
Blind_Squirrel is offline   Reply With Quote Top
Old 07-26-2007, 04:09 PM   #10 (permalink)
ed4copies's Avatar
Photos: 21
Default
Quote:
Much more worrisome, your chucks will tend to come loose (from the headstock) if you have a "tool catch". Depending on your RPM's this could be VERY dangerous.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
