| Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here. |
Welcome to penturners.org!You've found the home of The International Association of Penturners. You are currently viewing our site as a guest, which gives you limited access to view discussions, photos, and library articles.Consider joining our community today. You'll have full access to all of our content, be able to enter our contests, find local chapters near you, and post your questions and share your experience with our members all over the world. Membership is completely free!! If you have any problems with the registration process or your account login, please contact us. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
On the first pen I did, when it was done, I realized I didn't get all the sanding dust off before putting on a finish. On the next one, I used a buffing brush (for buffing shoes after polishing) to brush off the dust. I just put it up against the blank while it was still spinning and it got rid of all the dust.
So if you don't have an air compressor or don't want to use alcohol to clean the blank, grab the brush you might use to brush off your bench. I imagine that a paint brush would work as well. Hope this helps.
__________________
Rob
NW Fla http://members.cox.net/railrider1920/stories.html Not Pen or WW related. |
#5 (permalink) |
Photos:
I use a small paintbrush. Just give each blank a few good swats and you are good to go.
__________________
-Whayne
Mount Juliet, TN \"Technological progress has merely provided us with more efficient means for going backwards.\" ~Aldous Huxley |
#6 (permalink) |
Photos:
I have not had that problem. I use the bounce sheets and not problem at all. I got the idea off of a DVD that I have by Mr Paul Loseby. He is from England if I am not mistaken. I picked up a few ideas from him.
__________________
Brent Keever
Maurice La. |
#7 (permalink) |
Photos:
Do most of you sand your tubes on the lathe or by hand? When I have a bunch to do at one time I find the lathe method keeps my fingers from cramping:) I just lightly sand them with som strips of 240 grit.
__________________
Hoss
#9 (permalink) |
Photos:
I keep a paintbrush on the top of the lathe and brush the blanks between each sandpaper grit.
I clean the blanks with alcohol before applying finish. Sand tubes by hand. Larry
__________________
www.gottliebpens.com
| Bookmarks |
| Thread Tools | |
| Display Modes | |
