Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 11-20-2010, 10:11 PM   #1 (permalink)
Photos: 0
Default plating
Ok, I dont know if this is the right forum or not. But I am looking for someone that can do gold plating! Does anyone know where I can get gold plating done?????
jlmort1980 is offline   Reply With Quote Top
Old 11-20-2010, 10:22 PM   #2 (permalink)
ldb2000's Avatar
Photos: 240
Default
What kind of metal are you looking to get plated ?
__________________
Butch
Kitless Fanatic
The simplest method is usually the best solution (Me )
Any fool can know , the point is to understand (Albert Einstein)
There are no mistakes....Only happy accidents (Bob Ross)
http://www.penmakersguild.com/images.../logosmall.jpg
ldb2000 is offline   Reply With Quote Top
Old 11-20-2010, 10:27 PM   #3 (permalink)
Photos: 0
Default
Quote:
Doesnt matter at this point, I am looking at getting a center band made and plated, so it could be made out of anything.
Advertisement
Old 11-20-2010, 10:42 PM   #4 (permalink)
ldb2000's Avatar
Photos: 240
Default
Most Jewelry makers can do gold plating , they can plate brass or silver without too many problems . Most will do a triple plating of copper , nickel then gold for durability . A small part like a CB will cost you about $30 for a hardened gold plate . The problem is if you are going to use other kit parts the plating may not match in color .
__________________
Butch
Kitless Fanatic
Old 11-20-2010, 10:48 PM   #5 (permalink)
Photos: 0
Default
Well this pen will only have a centerband so I am not worried about the color. I would much rather find a CB with the OD of around .400" that I need instead of having to have one made but have not been so lucky yet.
Old 11-20-2010, 11:08 PM   #6 (permalink)
ldb2000's Avatar
Photos: 240
Default
Some of the euro/designer kits use a centerband that has an outside diameter of .406 according to the bushing chart .
__________________
Butch
Kitless Fanatic
Old 11-20-2010, 11:13 PM   #7 (permalink)
Photos: 0
Default
But I cant have the round over edge, I need to be flush on both ends and I think if I tried smoothing the edge square that I would ruin the finish. Unless you think that I could square that off without ruining the finish....
Old 11-26-2010, 05:26 PM   #8 (permalink)
Photos: 0
Default
You can turn one out of brass Or copper with standard woodworking tools. Then you get exactly what you want. Have the brass / copper plated afterwards. I'd make a dozen or so and get them plated in a batch.
Cincinnati is offline   Reply With Quote Top
Old 11-27-2010, 07:17 PM   #9 (permalink)
Photos: 0
Default
I've got 5 gold center bands that came from "mini designer" kits. They measure .416" o.d. and are about .120" thick. If you think they'll work for you, PM me your address and I'll send them to you.
mach9 is offline   Reply With Quote Top
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
