My pine cone pen instructions
Hernando, MS, USA.
Here is my attempt at giving instructions on making a pine cone pen
First start out with a cone about this size
(all I usually find on my land) some have larger ones.
I then cut it on a band saw to get ready for polyresin.
Next place the cone in some aluimiun foil or what ever container you want to use. I use the foil because after pouring the resin we go back to the band saw
Here is were you need to decide if its going to be a thick pen or maybe a slim line. The examples I will use here are of a new European pen I am making so it will require me to add a colored resin to fill gaps in the cone.
the top two are filled with a colored tan resin and the bottom with clear resin
these were turned round after cutting the resin that was poured in the mold.
Once they are round like this I then will drill them for the pen tubes and square off the ends
Important to note here is as you turn them to get round you will get closer to the pine and you will need to put some CA on as you go to prevent the pine cone from breaking off
this is one side of the two tans one turned with eurpean bushings
here is the opposite side of the same two tubes
Notice how the filled in areas are taken care of. Some say at this point it starts to look like a snake skin blank.
I usually do not turn all the way down to the final size because of fear it will break the cone. Remember more CA between turnings soaks into the core and helps prevent the ocone from flying apart. If you do have problems you usually can fill the gaps with shavings and CA.
Hernando, MS, USA.
I have all these pics clearer in a pdj file but not sure if its ok to post pdf file here.
If interested let me know or maybe Jeff may like the instructions
once again I must say part of this credit has to go to many others posting on here with thier ideas of pine cones and cactus pens. I am in no way trying to take away from what they have done. Just someone asked me to post a how too on this.
Dario
Austin, TX, USA.
Thanks Bob!
Those are really striking. I want to make some of those later too. (as well as several 1,000 others [8)][V] that I might not live long enough to try)
alamocdc
San Antonio, Texas, USA.
Originally posted by Dario
<br />I want to make some of those later too. (as well as several 1,000 others [8)][V] that I might not live long enough to try)
Tell me about it! My problem is that I have so many things that I want to try that I can't decide which one to start on.
emackrell
Baghdad, Iraq
Very neat pens!
Is the aluminum foil the mold, or does it line the mold? Just trying to visualize the process.
cheers Eileen [8D]
Hernando, MS, USA.
i only use the foil as the mold, then you can take it to the band saw and square up the sides before turning it round. Also important i forgot, when I put it on the lathe to turn round make sure you put CA on the ends so you dont put too much pressure on them and split them before you get to drill for the tubes
Hernando, MS, USA.
Pop and Jeff the process is the same as what Curtis O. Seebeck uses for the cactus pens, he has instructions posted on the home page, I want to especially thank him and others that have posted. The helped me put this different idea on my lathe to turn.
here are pictures of the finished euro.
PopPop
Sparta, TN, USA.
Originally posted by BobNashvillega
<br />Pop and Jeff the process is the same as what Curtis O. Seebeck uses for the cactus pens, he has instructions posted on the home page, I want to especially thank him and others that have posted. The helped me put this different idea on my lathe to turn.
Thanks Bob, I'll see if I can find Curtis's website and take a look. [:)]
Chuck
Hernando, MS, USA.
David,
not all require using poly, but if you want different affects you can use the smaller cones and the poly and get the snake (so i have been told) appearance. The trick is in the size of the cone you start out with and the design your looking for. If all cone is the end look then make sure you pick out a cone that has a center dia. big enough for the pen kit your using. and nice pen you made I might say too.
PopPop
Sparta, TN, USA.
<br />David,
David, that is one beautiful pen. What process did you use to get the resin to flow to the center of the cone? I just got a vacuum pot set up, but don't have a pressure pot yet. Dosen't the vacuum pot work as well as pressure for getting bubbles out of the resin? I checked out the tutorial that CS posted, but he didn't reference the vacuum system. [?]
Thanks,
Chuck
saftrep
Foxworth, Ms.
I don't use resin for the pine cone pens. I find them big enough (most of the time)for cigar sized pens. I could see using resin for smaller cones like Bob did.
David
PopPop
Sparta, TN, USA.
Thanks David. The pine cones that I can find around here are kind of small. By the time I saw the outside off to make a square blank, there isn't much left in the middle. I think I'm going to have to use the epoxy to even have enough to turn. [8D]
Thanks, Chuck
PopPop
Sparta, TN, USA.
<br />Poppop
Have you tried making a pine cone one yet!
No Bob I haven't tried to turn a pine cone yet. I have looked around for the resin and a pressure pot. HF has the pressure pot, but I haven't found the resin sited in the tutorial. I did find another 2 part epoxy resin counter top finish at Lowe's that should work, but it is a little pricey for me. I'm going to have to sell some regular pens before I try the pine cones. [8D]
Chuck
Skye
Rock Hill, SC
Originally posted by PopPop....HF has the pressure pot, but I haven't found the resin sited in the tutorial.....
I don’t want to get into a big.... thing.. but wouldn’t a vacuum setup be better for this?
PopPop
Sparta, TN, USA.
Originally posted by Skye
<br />
Originally posted by Pop Pop....HF has the pressure pot, but I haven't found the resin sited in the tutorial.....
That's the same question I asked myself. I thought back to when I made crowns & bridges (teeth), and packed the acrylic under pressure to cure it. We seldom had any problems with bubbles in it. I think the same principal would apply for this process too. Vacuum curing would not pull all the bubbles out of the resin. [:D]
Chuck
Hernando, MS, USA.
Thanks for the reply bob393. I certainly hope my posting has helped any that have wanted to try making these type of pens. I have noticed the numbers of views has gone up but no comments. Not sure if that is a good thing or bad. Here is my latest version of a pine cone that I made for the PITH 2006[:)] OH and it was my first attempt at this type of pen.
<br />
Hernando, MS, USA.
Here is my latest real Georgia Pine cone pen, I made this for James he saw my pens when I was working on my website
http://www.home.earthlink.net/~nadawg
it is my first attempt at making a pen larger than a slimline, I think it and the zebra wood pen turned out pretty good.
