Would anyone know of a supplier that would have a green marble round insert for a cheese serving tray, I am needing one 7-8 inches in diameter. CSUSA has them in 6 inch diameter, but I have a customer that wants one that is larger,
Check around for hard surface countertop suppliers and fabricators ... see if they have some offcuts you can have or purchase in genuine green marble or imitation marble (imitation might be better ... lighter weight, less absorption of smells and liquids). Cut it down to a size you can turn on your lathe and work it down to the proper size yourself... use a backer (glue block) and attach with double sided tape. Apply the insert to the cheese tray as recommended, I suppose ...
