keithncsu
So I know others have experienced this as well but I've had issues with Spectraply and the colored dust filling in pores and making it look not as crisp. It is most noticeable and looks the worst on blanks with the natural/white layer next to something dark - mainly blue in my experience. I've read on here that you can use sanding sealer, etc but I don't have any. I've also read you can use compressed air to blow the dust out before final finishing.
Now comes the laziness part. I turned a red/white/blue blank last night and got the same colored dust issue. Being lazy and it almost 10pm I did not want to pull out the air compressor and get it going. And I didn't have any canisters like you would use in an office environment. But I happened to notice a roll of handy duct tape. So I pulled a piece off and folded it over on itself. I used it to "peel" off the loose sawdust as if you were getting lint off of a piece of clothing. It was by no means perfect but it worked surprisingly well!!
The picture below shows the left blank after using the tape. The right blank is just as it was after sanding. You can see a difference for sure. I saw/felt no tape residue either - just in case you were wondering.
I'm sure it's not the best "trick" ever shared but it worked for me!!
