Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 10-05-2007, 08:04 AM   #1 (permalink)
Photos: 0
Default Key-chain toothpick holder from Berea
I made a key-chain toothpick holder from Berea for my father in-law, but he tells me that he is not using it because the cap keeps unscrewing itself. Anybody ever had this problem? Ay suggestion on hoe to solve this problem? I have more key-chain toothpick holder kit I would like to make but I don't want to sell them to people before I can solve this problem.
Thanks for your help!
__________________
I much prefer the smell of turned wood over the smell of turned milk.
To quote Pastor Bill: \"Jesus turned me\" also.
P.S. I\'m french, so I don\'t make any typo\'s. They are actual mistakes.
alparent is offline   Reply With Quote Top
Old 10-05-2007, 08:08 AM   #2 (permalink)
Activities Manager Emeritus
wdcav1952's Avatar
Photos: 6
Default
Consider a rubber ring like some use with other kits that have a tendency to to unscrew.
__________________
William "Cav" Cavanaugh
Susquehanna Valley, PA
“One of the consequences of such notions as "entitlements" is that people who have contributed nothing to society feel that society owes them something, apparently just for being nice enough to grace us with their presence.”
Thomas Sowell, PhD
wdcav1952 is offline   Reply With Quote Top
Old 10-05-2007, 08:13 AM   #3 (permalink)
kent4Him's Avatar
Photos: 1
Default
I've been making the CSUSA key chains and have recently moved to PSI's through WoodnWhimsys lately based on cost and plating. I have not had problems with either of them easily coming unscrewed. The CSUSA one that I personally use came unscrewed a couple of times in the two years I have used it, but I attributed it to not closing it tight and normal vibrations from having it in my pocket for long periods of time.
__________________
Chris Koterman
kent4Him Pens - Round Lake Beach, IL
"It could be worse...It could be raining."
"I love the smell of CA in the morning..."
kent4Him is offline   Reply With Quote Top
Advertisement
Old 10-05-2007, 08:51 AM   #4 (permalink)
Photos: 0
Default
Quote:
Any examples of that rign? Any links? Thanks
__________________
Old 10-05-2007, 09:38 AM   #5 (permalink)
arioux's Avatar
Photos: 0
Default
Hi Alain,
"O" rings are little black rubber ring that you will find in the plumbing department at your local hardware store. This will make a seal between the thread and the cap and making the cap to grap tight . Bring the keychain with you, a clerck should be able to find the right size. It sells for a few cents each.
You have some photo in wikipedia
http://en.wikipedia.org/wiki/O-ring
Alfred
__________________
Alfred
Terrebonne
Qc, Canada
arioux is offline   Reply With Quote Top
Old 10-11-2007, 06:19 AM   #6 (permalink)
Chapter Steering Committee
Glenn McCullough's Avatar
Photos: 34
Default
I threw the only one out that I made for that reason.
__________________
Glenn McCullough
ZIP IT!
Chesterfield, MI
goldmountainwoodworks.blogspot.com/
The best things in life...aren't things!
Glenn McCullough is offline   Reply With Quote Top
Old 10-11-2007, 07:34 AM   #7 (permalink)
wdcav1952's Avatar
Photos: 6
Default
Alain,
I'm sorry, I didn't get back to this thread. Alfred steered you in the right direction.
__________________
Thomas Sowell, PhD
Old 10-24-2007, 07:46 AM   #8 (permalink)
Photos: 0
Default
Thanks guys! My dad had a box full of every size of O rings you could imagine. Found the right one and put it on. It's now being tested by the owner (my father in law) I first put it on the thread itself but when you closed it, it was not as nice because of the black ring itself. So I've put it inside the cap instead and it seems to work fine. Time will tell.
__________________
Old 10-25-2007, 07:21 AM   #9 (permalink)
Photos: 0
Default
Talked with my father-in-law yesterday and the O-ring inside the cap works just fine. Best of all, it doesn't change the look.
__________________
Old 10-29-2007, 09:43 AM   #10 (permalink)
CHICAGOHAND's Avatar
Photos: 0
Default
i have tried the o ring and have had problems with it so i went back to the plumbing dept and found small rubber washers that fit better and they dont roll past the edge of the tooth pick holder.
i have not had anyone loose one yet.
__________________
Very few other professions require you do most of your best work in the dark with the power off.
http://www.anamericanwoodworker.zoomshare.com/0.html
CHICAGOHAND is offline   Reply With Quote Top
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
