How to clean micromesh?
Oakville, ON, Canada.
Originally posted by twoofakind
<br />I am about to try and clean mine. I read in the last post that someone uses one of those mesh laundry bags and washes them in the washer.
andy
That's how I do mine but I don't put them in the dryer - someone said the heat may damage them.
LanceD
Houma, La, USA.
Put them in a plastic container with a lid on it with some hot water and dishwashing liquid, shake it around for a minute or two, take them out, rinse them in the sink and lay them out on some paper towels to dry. All done in 5 minutes minus drying time.
jjenk02
Mary Esther, Florida, USA.
Originally posted by LanceD
<br />Put them in a plastic container with a lid on it with some hot water and dishwashing liquid, shake it around for a minute or two, take them out, rinse them in the sink and lay them out on some paper towels to dry. All done in 5 minutes minus drying time.
That sounds like an easier way to do it. I'll give it a try..
Originally posted by jjenk02
<br />George, do you just throw the mesh bag in with a load of laundry or do you wash them separately?
I just throw them in with the rest of the laundry. I don't think I'd try them with bleach though. The first time I washed them I put them in my jeans pocket but they fell out and I spent quite a while picking them out of the rest of the laundry[:eek:)]
martyb
Des Moines, IA, USA.
Stuff mine in a couple pants pockets and run them through the wash (not the dryer mind you)
It'll take care of 90% of the material, but some of the courser pads may have a little left in them depending on how often you clean them and how aggressively you were using them on some acrylic. (yeah, I did it too [:D]) Those get a toothbrush and water scrub.
Rudy Vey
South Plainfield, NJ, USA.
I give mine to my wife, she returns them clean, dry and in order of the grits a day later. Once in a while she gets a free pen for this service....[:D]
(but I know she uses the mesh baggie for them, she has one that is only used for my MM).[;)]
kenwc
Dallas Texas
The answer is obvious...we all send our MM to Rudy and he'll get his wife to clean them. Then Rudy makes her a pen for her Trouble. Can't get any easier than that..!!!
Fangar
Wilton, CA, USA.
I keep it in the side pocket of my turning frock when I wash it. In fact sometimes, I just wear my turning frock into the shower with my MM in the pocket. Believe it or not, the 1500 makes a pretty fair acne scrub too.
[:D]
Fangar
mdburn_em
Chesapeake, VA, USA
Guess I didn't know any better but I throw them in a mesh bag and then into the washer with my jeans. Then into the dryer. The only damage ever done to my MM is when I press too hard at the lathe.[:I]
Chesapeake, Va, USA.
I had a friend over the other day; I was teaching him how to make a pen. We went through all the MM grits. He asked me how I clean my pads. I told him about a drop of dish soap in some water and a sealed container, then shaking for a bit. He said "have you ever considered trying an ultrasonic cleaner?" [:0]
Well I did just that last night; they came out GREAT! My ultrasonic is only big enough to float two in at a time. I did one side for a minute, turned them over, did the other side for a minute, took them out and rinsed them under running water. You should see all of the junk that came out!
