Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Closed Thread
Old 09-11-2007, 06:45 AM   #1 (permalink)
skiprat's Avatar
Photos: 174
Default Holesaw segmenting in plastics
Here's a trick I used to make a recent pen. I wanted to have a round segment in the main body of the material. I selected two holesaws, one the next size to the other. The smaller one will make the cutout in the main body and the larger one cuts the segment that will get glued in. ( using the outside of the kerf of the small one and the inside kerf of the bigger one) Even doing this leaves a gap, so I just lightly held the matching parts in a vice and slowly heated the joint with a heat gun ( on low ) As the plastics start to get soft, gently close the vice while still warming the bits. (I also warmed up the vice and bit of steel) Leave it in the vice till it's COMPLETELY cold.
These are the two pairs of similar holesaws, 1 pair for the body and the other for the cap
Here I am cutting the segment using the larger holesaw from each pair. I left the pilot bit out.
Here you can see that even using matching holesaws, the gap is too big
Holding it the vice and heat it up while gently closing the vice. ( I also sanded most of the rough marks off that were caused by the holesaws) The segment was wider than the vice jaw, so I just added the chuck of metal. I concentrated the heat on this bit of metal. Leave it in the vice till it's cold.
Here's the pen again, no visible glueline:D
I have used this method when segmenting plastics into wood too, just pre warm the plastic before putting it in the vice. Hope this is useful to someone.;)
__________________
skiprat is offline   Top
Old 09-11-2007, 09:04 AM   #2 (permalink)
Activities Manager Emeritus
wdcav1952's Avatar
Photos: 6
Default
Dang, Skip, you come up with some nifty ideas!!
__________________
William "Cav" Cavanaugh
Susquehanna Valley, PA
“One of the consequences of such notions as "entitlements" is that people who have contributed nothing to society feel that society owes them something, apparently just for being nice enough to grace us with their presence.”
Thomas Sowell, PhD
wdcav1952 is offline   Top
Old 09-11-2007, 10:16 AM   #3 (permalink)
Local Chapter Manager
ed4copies's Avatar
Photos: 21
Default
Pretty clever, Skippy!!!!!
I recognize that PR (it's from the Princess!!)
__________________
Ed Brown - ZipIt--to help build chapters (click for explanation)
"Often copied....NEVER duplicated!!!"
Now offering Berea Baron and Sedona pens!!
click on blue to see what's NEW
"If you have not visited today, you missed new products!"
ed4copies is offline   Top
Advertisement
Old 09-11-2007, 10:45 AM   #4 (permalink)
Paul in OKC's Avatar
Photos: 6
Default
Aaaahhh, ya beat me to it. Had an idea like that, just haven't got there yet. Looks great!
__________________
Paul in OKC, OK
If you meet me and forget me, you have lost nothing. If you meet Jesus Christ and forget Him, you have lost everything.
"When wealth is lost, nothing is lost; when health is lost, something is lost; when character is lost, all is lost." Billy Graham
“Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety.” Benjamin Franklin
Paul in OKC is offline   Top
Old 09-11-2007, 11:23 AM   #5 (permalink)
gketell's Avatar
Photos: 51
Default
Thanks for sharing that, Steven. I had been looking at your pens and your comment about two hole-saws but I knew they didn't match and couldn't figure out that solution. Now I know!!! Thanks!!
Paul,
Get used to it, That has happened to me about 3 times so far. [:D] The truly sad thing is that each time their version is way above what I was even envisioning. [:(] (for me) [:D][:D][:D] (for them!)
GK
__________________
Greg Ketell
Permanent Penturning Newbie
Pleasanton, CA
gketell is offline   Top
Old 09-11-2007, 02:10 PM   #6 (permalink)
Photos: 0
Default
Have you thought of trying to modify the hole saws to reduce the set on the teeth. Pull in the outer teeth of the larger saw and pull out the inner teeth of the smaller one. Not even sure if you can do this but it seems you have a lot of experience with metal.
__________________
Thanks,
David
www.Briskibusiness.com
dbriski is offline   Top
Old 09-11-2007, 05:45 PM   #7 (permalink)
tipusnr's Avatar
Photos: 71
Default
Simple, handy solution (I LIKE simple) requiring very little extra expense. GREAT!!
__________________
Bill "Tip" Tippery
Have fun...life's hard enough!
Reynoldsburg, OH
tipusnr is offline   Top
Old 09-11-2007, 10:12 PM   #8 (permalink)
Photos: 0
Default
Wow! That's what I call creativity. The practical kind too, like Tip said. That's the kind of thing that keeps me turning. When something starts to get kind of boring, look for a new idea. You must be one of those people who's always experimenting. Keep up the good work!
__________________
Hoss
Hosspen is offline   Top
Old 09-12-2007, 12:41 AM   #9 (permalink)
Ligget's Avatar
Photos: 131
Default
Very good idea Steve, love the colour combination! [:p]
__________________
Ligget is offline   Top
Old 09-12-2007, 03:39 PM   #10 (permalink)
papaturner's Avatar
Photos: 195
Default
Thanks for the tip,that`s using your head for something other than a hat rack.
__________________
Perry Bridges
Buchanan,Georgia
That too shall pass.
papaturner is offline   Top
Closed Thread
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
