Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Closed Thread
Old 01-01-2007, 03:28 AM   #1 (permalink)
Photos: 0
Default help please
I have a Record mini lathe and it has # 1 MT tailstock and headstock.
I have an adapter to make it go from 3/4x 16 tpi to 1x8tpi. Is there an adpter to make the tailstock 1x8 tpi so I can use my 1x8 drill chuck ? If there is where can I buy one.
Thank you
__________________
John E. Duck
Mt Enterprise, Tx
old folks is offline   Top
Old 01-01-2007, 09:01 AM   #2 (permalink)
mewell's Avatar
Photos: 4
Default
Not sure if this is what you're after, but go to woodturnerscatalog.com and search on "adapter"
Mark
__________________
Mark Ewell
www.reMARKablepens.com
mewell is offline   Top
Old 01-01-2007, 10:20 AM   #3 (permalink)
Photos: 68
Default
Are you looking for this?
http://www.bestwoodtools.com/ have similar TAILSTOCK CHUCK ADAPTERS but comes only in the following ARBOR SIZE:
3/4" - 16 TPI has a #1 Morse Taper
1" - 8 TPI has a #2 Morse Taper
1" - 12 TPI has a #2 Morse Taper
1-1/4" - 8 TPI has a #2 Morse Taper
1-1/2" - 8 TPI has a #2 Morse Taper
33 x 3.5mm has a #3 Morse Taper
This is the reason why MT1 lathes is discouraged...only a few manufacture accessories for it.
__________________
Dario
Austin, TX USA
"Pictures in your mind are memories" - Kathryn O., 3.5 years old
Dario is offline   Top
Advertisement
Old 01-01-2007, 07:24 PM   #4 (permalink)
Photos: 0
Default
[quote]Originally posted by mewell
<br />Not sure if this is what you're after, but go to woodturnerscatalog.com and search on "adapter"
Mark
I don't know how to post a pic but is this what is needed to use # 2 MT tools in my tailstock ?
http://www.woodturnerscatalog.com/cgi-bin/shopper?preadd=action&key=192-0005
Thank You
__________________
John E. Duck
Mt Enterprise, Tx
Old 01-01-2007, 07:35 PM   #5 (permalink)
Photos: 0
Default
[quote]Originally posted by old folks
<br />
Mark
Thank You
No. That would be used if you had a #2MT tailstock and wanted to use #1MT devices in it. If I understand correctly, you want to go in the opposite direction. I don't think it can be done.
__________________
If it ain\'t broke, fix it till it is.
randall844 is offline   Top
Old 01-01-2007, 07:40 PM   #6 (permalink)
Photos: 0
Default
As far as converting from 3/4X16 TPI to 1X8 TPI, it would only require a sleeve with the appropriate threads inside and outside. I'm sure such a thing would be easily available
__________________
Old 01-01-2007, 08:09 PM   #7 (permalink)
Photos: 45
Default
John - This drill chuck will fit in your 1MT without an adapter. http://www.highlandwoodworking.com/index.asp?PageAction=VIEWPROD&ProdID=370
__________________
Pogue Mahone.
Nescencia necat.
DCBluesman is offline   Top
Old 01-02-2007, 01:39 AM   #8 (permalink)
Photos: 0
Default
John, Here's a cheaper solution!
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&cat=Po wer+Tool+Accessories&subcat=Lathes&pid=00925354000
While it may not be as pretty as Lou's, it can be used for other things in the MT1 headstock as well. Such as? [?]
Well, aside from it's use as a drill chuck on either the head or tail stock. It could be used on the head stock as a small buffer, a disk sander, or even a mini-grinder? Probably not the best solutions for those needing these tools but certainly usable, at least temporarily or for a quick-use work station accessory. They used to sell these in MT2 sizes, also.
Hope this helps.[:)]
__________________
Bob
Muncy, Pa.
Thumbs is offline   Top
Old 01-02-2007, 08:52 AM   #9 (permalink)
mewell's Avatar
Photos: 4
Default
<br />
Mark
Thank You
Call their 800 number and ask for tech support. I'd say that based on the wording on the web page it may be what you want, but best to talk to a person to make sure.
Mark
__________________
Mark Ewell
Old 01-02-2007, 09:12 AM   #10 (permalink)
Photos: 68
Default
Quote:
Originally posted by randall844
<br />
Actually you can go the other direction, I've seen some...but the adapter will be much longer and will shorten your effective bed length.
Like this...
http://cgi.ebay.com/Morse-Taper-Extension-Socket-MT2-Hole-MT1-Shank_W0QQitemZ160030568648QQihZ006QQcategoryZ1096 81QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
If this will work, I think it is a good investment since you can buy and use MT2 accs which you can use later if you upgrade. [;)]
__________________
Dario
Austin, TX USA
Closed Thread
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
