help I cut it off to short
Justturnin
Houston, Tx
How Much brass? Slims are fairly fogiving just adjust the amount you press the tranny in to make up for it if it was on the bottom tube and if on the top you should be fine assuming you didnt clean off 1/2" of brass.
Andrew_K99
Waterdown, ON, Canada
Top or bottom barrel? How much shorter is it?
If it isn't much the top barrel can just be left as is. If it is the lower barrel just insert the tansmission a little less.
AK
GoodTurns
Bowie, MD, USA.
assuming you didn't take like half the blank off....you can just seat the transmission a touch higher (don't push it in as far as normal) and everything will be fine!
pensbybruce
indianapolis southside
I believe I cut off about 1/8 of an inch. I thought my blank was for pencil which is a shorter length. Maybe I should just make a pencil out of it and cut the other end shorter also to make a pencil. sure appreciate all the quick responses.
PenMan1
Eatonton, Georgia
An 1/8th inch on a slim should be very workable. If it is the bottom tube, just go slow and check frequently when pressing in the tranny.
THarvey
Anniston, AL, USA
I am assuming you cut it before you turned the pen. Use the shorter piece for the top of the slim. If it is not long enough to cover the transmission, turn a contrasting material for a wider centerband.
randyrls
Harrisburg, PA 17112
Bruce; You can do either of the options above. Modifying the slimline by changing the length of the upper or lower tube is an easy way to customize the slimline.
You can get 7mm brass tubes in 10" or 12" lengths from several suppliers.
