Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 02-17-2012, 10:21 AM   #1 (permalink)
Photos: 0
Unhappy help I cut it off to short
When I was making an acrylic pen I cut not only the acrylic but part of the brass tube is there a way to fix this? it was a slimline pen.
pensbybruce is offline   Reply With Quote Top
Old 02-17-2012, 10:24 AM   #2 (permalink)
Justturnin's Avatar
Photos: 0
Default
How Much brass? Slims are fairly fogiving just adjust the amount you press the tranny in to make up for it if it was on the bottom tube and if on the top you should be fine assuming you didnt clean off 1/2" of brass.
__________________
Chris B
God's work lies with those who help lives and not in those who destroy them
Justturnin is offline   Reply With Quote Top
Old 02-17-2012, 10:24 AM   #3 (permalink)
Andrew_K99's Avatar
Photos: 10
Default
Top or bottom barrel? How much shorter is it?
If it isn't much the top barrel can just be left as is. If it is the lower barrel just insert the tansmission a little less.
AK
__________________
Andrew
Andrew_K99 is offline   Reply With Quote Top
Advertisement
Old 02-17-2012, 10:25 AM   #4 (permalink)
GoodTurns's Avatar
Photos: 27
Default
assuming you didn't take like half the blank off....you can just seat the transmission a touch higher (don't push it in as far as normal) and everything will be fine!
__________________
Jon Piper - Beautiful Downtown Bowie, MD
constantly surprised at the number of great people we have here!
www.goodturnsartshop.com
GoodTurns is offline   Reply With Quote Top
Old 02-17-2012, 10:25 AM   #5 (permalink)
Photos: 15
Default
How much too short is it?
__________________
Mark
MarkD is offline   Reply With Quote Top
Old 02-17-2012, 10:25 AM   #6 (permalink)
Andrew_K99's Avatar
Photos: 10
Default
4 responses within 4 minutes, don't you just love the IAP!
__________________
Andrew
Old 02-17-2012, 10:35 AM   #7 (permalink)
kronewi's Avatar
Photos: 6
Default
Yes, I like how helpful people are here. It is nice.
Kevin
kronewi is offline   Reply With Quote Top
Old 02-20-2012, 04:45 AM   #8 (permalink)
Photos: 0
Default
I believe I cut off about 1/8 of an inch. I thought my blank was for pencil which is a shorter length. Maybe I should just make a pencil out of it and cut the other end shorter also to make a pencil. sure appreciate all the quick responses.
Old 02-20-2012, 05:40 AM   #9 (permalink)
PenMan1's Avatar
Photos: 82
Default
An 1/8th inch on a slim should be very workable. If it is the bottom tube, just go slow and check frequently when pressing in the tranny.
__________________
Andy Little
entia non sunt multiplicanda praeter necessitatem. The popular interpretation of this principle is that the simplest explanation is usually the correct one. -Occam's Razor
Common sense isn't always such a common thing.
If it ain't broke.......then a little duct tape won't hurt it!
PenMan1 is offline   Reply With Quote Top
Old 02-20-2012, 06:19 AM   #10 (permalink)
THarvey's Avatar
Photos: 22
Default
I am assuming you cut it before you turned the pen. Use the shorter piece for the top of the slim. If it is not long enough to cover the transmission, turn a contrasting material for a wider centerband.
__________________
Tim Harvey
Evicted from the 2013 Birthday Bash Losers Club - Winner Day 15 Wood ID
2nd Place 2013 Birthday Bash Casting - Tube On contest (with my first ever cast)
THarvey is offline   Reply With Quote Top
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
