| Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here. |
Welcome to penturners.org!You've found the home of The International Association of Penturners. You are currently viewing our site as a guest, which gives you limited access to view discussions, photos, and library articles.Consider joining our community today. You'll have full access to all of our content, be able to enter our contests, find local chapters near you, and post your questions and share your experience with our members all over the world. Membership is completely free!! If you have any problems with the registration process or your account login, please contact us. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Location: Middletown,PA via The Coal Region,Pittston, PA, USA.
Photos:
Has anyone had trouble gluing brass tubes with 2 part epoxy? I have had 2 out of 10 fail, this is not acceptable. I have painted the outside of the tubes and tubes came out when I was using the barrel trimmer. I did notice that there was no paint on the tube that was exposed. I don’t know if it came off from the tube spinning in the blank or if there was a reaction with the glue. Any help would be appreciated.:(
__________________
#2 (permalink) |
My first guess is that the ends of the tubes were not entirely clear. If even a small amount of epoxy gets into the tube and isn't entirely cleaned out, it will potentially heat up and bind the tube to the end mill shaft. The center shafts on the ends mills don't do much to dig out excess adhesive.
Plugging the end of the tube before interting it is the first defense against this, you might also try cleaning it out with a slightly smaller drill bit, I use a chain saw file to girnd out stubborn bits of epoxy or CA. Try sliding the tubed blank on the mandrel before end milling. If it will slide over the mandrel, then it is clean on the inside of the tube.
__________________
Often wrong, never in doubt.
#3 (permalink) |
I use nothing but epoxy and had one failure because of squeze out, meaning as the glue cured it pushed the tube out a little. I would try painting the inside of the blank more than the tube. Also try tinting the epoxy. It sounds like what you used to color the tubes would not bond to the tubes, espcially if there was no paint at all on the tubes when they came out.
__________________
Benjamin T. |
| Advertisement |
#5 (permalink) |
I paint the insides of the blank with Testors model paint instead of the tubes. Also, try lightly sanding the tubes on the lathe with 120 grit paper to remove any oils / contaminates and give the epoxy a good surface to adhere to. Since I changed from painting the tubes, I have not had any failures.
__________________
www.creativependesign.com
#6 (permalink) |
Jim, I use nothing but epoxy and haven't had a problem. Make sure you scuff the tubes.
__________________
Billy B.
San Antonio, TX www.acdcreations.com "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan |
#7 (permalink) |
Photos:
I don't know what you mean by "fail". All I use is two part epoxy. Never a problem. I'm kinda sloppy and have to clean drops from the ends sometimes. Also, I don't understand Chaspers "will potentially heat up and bind the tube to the end mill shaft". I think he is talking about problems that do not exist.
Here is how I do it: rough tube with coarse sandpaper, apply epoxy to tube, put tube into hole. Nothing complicated. Works.
__________________
Frank
Mountain Home, Arkansas \"All animals are equal, but some animals are more equal than others.\" from Animal Farm by George Orwell |
#9 (permalink) | |
Quote:
__________________
-Scott
Chesapeake, Va. |
#10 (permalink) |
Photos:
If I rough up the tube and then paint it so much for the roughness the paint just filled that in. If I paint it and then rough it up so much for the paint. What I ment by fail was it doesn't work.I have to paint the tubes because the tube shows through my blanks 90% of them. I think I will try the model paint and tinting to epoxy or maybe try thick CA glue. Thank you for all your input guys. If I have any more problems I will let you know.
Thanks, Jim:)
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
