decals on blanks
srs64
Dothan Al
I picked up a few all white blanks and was trying to put some decals on the with very mixed results. Seem like the CA does not like the acrylic. I turn it to desired shape and sand it then wet sand till smooth, no polishs apply decal...... let dry
then apply CA in thin layers, sorta looks like fisheye on a old car I painted?
Any ideas on a better way to do it?
Sherman
RMayoIII
Belmont, NH
Some pics might help us understand what result you're getting. Almost sounds like you may have trapped moisture under the decal. Do you blot them on firmly to squeeze out excess from beneath them? May also have something to do with your brand of CA. Did you re sand/polish the CA after applying? I've never gotten it to be flaw free, always have to flatten and polish it out myself.
Jim Burr
Banned
Reno, Nv
Robert has a good point. Moisture and CA don't mix until the CA is cured and it's time to wet sand.
NittanyLion
State College PA
Sherman,
I have tgis happen every so often. For me its a result of the decal paper not being sealed properly. Are you clearcoating the decal paper?
firewhatfire
Columbiana, Alabama
here is one I just finished on acrylic. I will agree there has to be some moisture somewhere.
homemade
Huntsville, AL
Dacals
This is what I have done. I print out my own decals on Testors clear film and fix it with the Testors decal bonding. I let it set up for 24 hrs. after that, I apply the decal to the wood or blank and allow it to set up for another 12-24 hrs so that all the moisture evacuates, This is where it get tricky. I apply a thin film of CA using a poly foam strip. I let it glide across the decal at a very slow rpm. I let it set up to dry for an hour to make sure that the CA does not react with the bonder. Apply another thin film of CA and keep repeating this process. If you get any raised areas, sand only those areas. When you inspect the decal and see that it is sealed, then you can move onto medium weight CA to complete the finish. As I say this is trial and error. If anyone out there have any ideas on this matter, please let me know. By the way I printed my labels using a laser printer making it a very sharp image.
Janster
Nevada
.........make the decal.
.........Let thoroughly dry
.........spray w/ Krylon Fusion Clear, TWICE, but let it dry between coats
.........apply to pre finished blank if it porous,aka "wood"
.........build up w/CA or cast and finish....Works for me! Good luck and be well.....Jan
