| Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here. |
Welcome to penturners.org!You've found the home of The International Association of Penturners. You are currently viewing our site as a guest, which gives you limited access to view discussions, photos, and library articles.Consider joining our community today. You'll have full access to all of our content, be able to enter our contests, find local chapters near you, and post your questions and share your experience with our members all over the world. Membership is completely free!! If you have any problems with the registration process or your account login, please contact us. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
I buy my sandpaper in sheets, so here are two tips that may or may not be helpful for you.
Tip #1: Make one of these. Nothing more than a hacksaw blade that I had bent, and thus was no longer useful in the hacksaw. It's screwed to a piece of scrap poplar with a washer under one end. I use this to cut my sandpaper into smaller strips. The paper goes in the jig face down, and you just pull up against the blade and it cuts the paper like butter, no dulling of a razor blade, or any other sharp blades to cut with. ![]() Tip #2: I store the cut strips of sandpaper in a storage box. This particular one came from HF. They are currently having a sale on them for around $2 and some change.
__________________
It's not the size of the shop, but how you use it!
![]() Justin |
#6 (permalink) |
Photos:
I made a sandpaper "cutter" similar to this about 20 years ago after seeing it in a magazine. The one I have has a washer at both ends to make it easier to slip thicker sheets under it. I also used a larger (not as easy to store as this one) sheet of wood, but I put lines on it so that I would know where I wanted to make cuts. I suppose you could mark it off like a paper cutter, but I just did a couple of lines for my normal sizes. I am still on my original blade. It is a great idea and works really slick.
Jerry
__________________
#7 (permalink) |
I will definitely use that idea for my sandpaper. Paying it forward, if I can offer this tip that has worked for me...I use that same case from HF (usually around $4 on sale) along with empty film canisters to keep my bushings organized. If you go into any place that processes film and ask for their used film canisters, they will gladly give them to you for free. Try to get the clear ones so you can write on the side instead of the top, easier to see. They fit perfectly in the divided slots in the case.
#8 (permalink) |
the sandpaper idea is brilliant.
But I also like Bob's bushing storage idea. Hubby got me a storage set (http://www.woodcraft.com/Product/202...wer-Large.aspx) for christmas, and I think the film canisters will work PERFECTLY in it. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
