Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 09-08-2008, 05:32 PM   #1 (permalink)
woody350ep's Avatar
Photos: 1
Default Corian gluing???
I went to a local cabinet shop today and got a scrap piece of Corian to try and make a pen out of. I say TRY because I don't know if it will work or not. It is only 1/2" thick. He said that the stuff used to come in 3/4 but now it comes 1/2 since that is all that is needed. Does anyone know about this? I would assume I could still get 3/4, but I may be mistaken. At any rate, I have a piece of 1/2" thick corian and would like to know what type of adhesive I could use to glue 2 pieces together and turn, if at all possible. He told me they use a special adhesive that comes with the product when they get it, but I would think something else would work well enough, maybe CA?? I know someone around here has probably done this, so please help me out with any advice, TIA.
__________________
Jason Woodford
South Bend, IN
AM General (I builds me some Humvees)
"As of right now, this is the oldest I have ever been."
"When you're lucky, CRAP for brains will do." - Grandpa
woody350ep is offline   Reply With Quote Top
Old 09-08-2008, 05:38 PM   #2 (permalink)
hewunch's Avatar
Photos: 3
Default
You can make a slim line out of 1/2 no problem. Or you can glue to pieces together with Med ca. Rough up the polished faces add glue and clamp tightly. Let sit 24 hours.
__________________
"Grow, grow where you are, anchor your roots underneath. Doubt your doubts, and believe your beliefs"
hewunch is offline   Reply With Quote Top
Old 09-08-2008, 05:50 PM   #3 (permalink)
woody350ep's Avatar
Photos: 1
Default
OK, I was thinking I could but wasnt sure. I have only been doing these for about 2 weeks now. Wow, 24 hrs on a CA glue, but need some serious adhesion. Could I rough them with some 150, or is that too high?
__________________
Jason Woodford
South Bend, IN
Advertisement
Old 09-08-2008, 06:07 PM   #4 (permalink)
SamThePenMan's Avatar
Photos: 9
Default
I've made a few pens out of 1/2" corian. I've got a few on my website and I just uploaded a picture of a pen/pencil set to the members photo gallery.
While I was working at a high school, one of the teachers/coaches there had a father-in-law who owned cabinet store. We'd get huge sheets of scrap corian that was 1/2" thick.
You just have to really make sure that you drill on center and that the drill bit is going true, other wise you may blow out the side. Also leaving the blanks a tad bit longer helps, as you don't have to drill all the way through, then just sand off the end, or if your careful you can chop it off at the miter or band saw.
Even though you can't really do much with a 1/2" blank it still looks pretty good after sanding and polishing.
__________________
Sam Bowen aka Sam the Pen Man
Turning the World one pen at a time.
Skype: Samuel.M.Bowen
Website: www.bowencustomcreations.com
Learn how social networking can work for you. To find out more
Visit: www.samspeoplestring.com
SamThePenMan is offline   Reply With Quote Top
Old 09-08-2008, 06:09 PM   #5 (permalink)
Mack C.'s Avatar
Photos: 110
Default
Hi Woody; Make sure you are gluing the 2 good faces together. That way you have 2 very flat surfaces that really need only to be scuffed with 220 grit or higher.
After the CA and clamping (24 hrs. isn't necessary) I wouldn't attempt drilling & turning till the next day. Just my opinion.
The glue joint is very important and if done properly you won't be able to discern it after tutning.
Good Luck!!
__________________
Mack C. in Brooklin ON
It feels great to sell a pen;
It feels even greater to give one to a friend!
I am a proud supporter of
"Pens for Canadian Peacekeepers"!
477 kms from my daughter in Milford MI.
Mack C. is offline   Reply With Quote Top
Old 09-08-2008, 06:38 PM   #6 (permalink)
woody350ep's Avatar
Photos: 1
Default
I take it a barrel trimmer is out of the question on this, eh :-) Should I trim it up in a disc sander instead?
__________________
Jason Woodford
South Bend, IN
Old 09-08-2008, 06:47 PM   #7 (permalink)
hewunch's Avatar
Photos: 3
Default
nope I use a barrel trimmer all the time with it. I said 24 hrs because some experts said it still gets harder up to 24 hrs later.
__________________
Old 09-08-2008, 08:00 PM   #8 (permalink)
Photos: 0
Default
Jason,
I can get 3/4" solid surface so it's still available. Maybe not from all manufacturers but, I buy mine direct. Use CA to glue it up and it's only necessary to wait until the glue is dry(30 mins. max is all I wait). If it is dry on the outside edges you should be ok.
What shop did you get yours from? I'm in Elkhart and could probably get some of the 3/4" for you. I can also get 1/4" which is what I mostly use.
DozerMite is offline   Reply With Quote Top
Old 09-08-2008, 08:05 PM   #9 (permalink)
PaulDoug's Avatar
Photos: 16
Default
I've glued 6 3"X6" pieces together to make a little vase, Sand the sides to be glued on 220 or 300 sandpaper laid on a flat surface. I did it on my table saw table. Once the sides are flat cover both side to be joined with a good coat of medium or thick CA. You can spread it by rubbing the pieces together but be pretty quick. Than clamp snugly and let sit for 24 hr like said. Took me four days to glue the 6 pieces together because I let it sit 24 hours each time I glued a new side one. Small pieces for a pen should be pretty straight forward. BUT DRILL SLOWLY when drilling for the tubes.
I have seen 3/4 inch stock on e-bay several times.
__________________
"We the People ....."
PaulDoug is offline   Reply With Quote Top
Old 09-08-2008, 08:34 PM   #10 (permalink)
woody350ep's Avatar
Photos: 1
Default
James, I got it from a place on 20 I think called Focal Point Cabinetry. Just west of Ash where the new Walmart is. Where do you get yours from? PM me if you'd like, we may be able to get something worked out......
__________________
Jason Woodford
South Bend, IN
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
