Cactus juice - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
  Forgot Password
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 01-10-2017, 02:02 PM   #1 (permalink)
Photos: 0
Default Cactus juice
Has anyone run two vacumn cycles on the same batch of wood using cactus juice? Just wondering if there would be any advantage as far as the wood retaining more of the juice.
tom wood is offline   Reply With Quote Top
Old 01-10-2017, 04:42 PM   #2 (permalink)
Photos: 0
Default
Yes. But it depends on what you are trying to accomplish if you need to or not.
If you are doing a 2 color stabilization, then you might try soaking (no vac) the wood in the lighter color for a day or two, then bake it, then sand of the outer crust, then put it under vac with the second color, then bake again.
If you are doing something like a corn cob that is really porous, then 2 cycles through may help.
If you are doing a normal piece of soft or punky wood, and only doing clear or one color, then 1 time through should be enough. If it isn't then you aren't pulling enough vacuum or the wood might not be a good one to stabilize (really hard or oily woods usually aren't the best for this process)-my opinion. Others will definitely differ.
Dave
lyonsacc is online now   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
