Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 07-19-2011, 10:39 PM   #1 (permalink)
okiebugg's Avatar
Photos: 7
Exclamation CA Glue....saving the tips
With the days of an early summer heat wave, (we've had 100degree days for 18 days) and high relative humidity above 70% here in Oklahoma, I've figured out (for what its worth) how to keep your glue tips from jamming up and glue setting in the nozzle. First, never throw away a tip or a cap from an empty bottle....They can be reused. I have enough tubes and caps now that I don't need to buy any.
Use a glass jar (I use large baby food jars) fill the jar with acetone and keep it sealed tightly. At the first sign that your tube is getting plugged or starting the inevitable buildup of glue on the exterior, throw it in the acetone for 4 or 5 hours. In the meantime take one of your used tubes and caps which you have cleaned and put it on the glue bottle you're using. Voila, starting over with a 'new tip'
I use satellite city thick CA and med CA. I like a different type of thin made by loctite because of its ease of application and the seal it gets when you put the cap on it. This also needs the acetone bath at times.
After allowing your nasty tip sit in the acetone for a few hours, start swirl shaking the jar a few times and fish the tip out with forceps. (I dont like it on my skin) The acetone will remove virtually all of the CA from the tip and cap so it can be reused.
The downside if there is one, is the acetone in the jar is itself turning into a 'lite' super glue. It will become milky and change to a slightly amber color. Open the jar and throw it out safely. If you get it on anything, it will stick to it.
okiebugg is offline   Reply With Quote Top
Old 07-19-2011, 10:42 PM   #2 (permalink)
seamus7227's Avatar
Photos: 136
Default
thanks for sharing!
__________________
~~~~"ZipIt"~~~~~
Home of the Tru-Quarter™ Blanks
~Snakeskin Blank Supplier~
http://www.texomapens.com
seamus7227 is online now   Reply With Quote Top
Old 07-19-2011, 11:39 PM   #3 (permalink)
KenBrasier's Avatar
Photos: 0
Default
I've stopped capping my CA and it has almost completely ended any stopping up problems. I haven't noticed it drying out either, I've had some uncapped for almost a year without any issues.
__________________
Ken
KenBrasier is offline   Reply With Quote Top
Advertisement
Old 07-20-2011, 07:11 AM   #4 (permalink)
scotirish's Avatar
Photos: 6
Default
If the individual at my local Woodcraft Store knows what he is talking about, ca glue cures (hardens) in the ABSENCE of oxygen. So I also no longer cap the bottles and have no problem with hardening. To clear the spout I slam the bottle down on the bench and the glue goes back in the bottle.
Ron
__________________
scotirish
Work safe!
SUPPORT OUR TROOPS!
scotirish is offline   Reply With Quote Top
Old 07-20-2011, 07:13 AM   #5 (permalink)
snyiper's Avatar
Photos: 4
Default
I am with Ken I just sit it down tap it and puff air out the tip and leave it ..I have had some open for several months no issue.
If CA hardens due to the absence of oxygen why do we get our fingers glued up? If that theory were true if you put it on a open piece of wood it will not harden....I think there is more to it.
__________________
Glenn
St Inigoes Shores, MD
"Gun control is never having to say I missed you"
snyiper is offline   Reply With Quote Top
Old 07-20-2011, 07:20 AM   #6 (permalink)
snyiper's Avatar
Photos: 4
Default
I found this and it makes sense. I have used misted water to set CA when I raced RC trucks we never used accelerator.
Generally, cyanoacrylate is an acrylic resin which rapidly polymerises in the presence of water (specifically hydroxide ions), forming long, strong chains, joining the bonded surfaces together. Because the presence of moisture causes the glue to set, exposure to moisture in the air can cause a tube or bottle of glue to become unusable over time. To prevent an opened container of glue from setting before use, it must be stored in an airtight jar or bottle with a package of silica gel. Another convenient way is attaching a hypodermic needle on the opening of glue. After applying, residual glue soon clogs the needle, keeping moisture out. The clog is removed by heating the needle (e.g. by a lighter) before use.
__________________
Glenn
Old 07-20-2011, 07:33 AM   #7 (permalink)
Photos: 2
Default
Good info all but I saw not mention of storing Ca in refrigerator. I keep my large bottles in the refrigerator and have no issue at all. Does it need to be kept there??
Gary
SGM Retired is offline   Reply With Quote Top
Old 07-20-2011, 10:10 AM   #8 (permalink)
okiebugg's Avatar
Photos: 7
Default
Quote:
Ron
Hey SGM Retired.....I'm CSM retired..........SEMPER FI
That individual may or may not be correct. Water molecules in ambient air causes CA to cure. The higher the humidity, the faster the cure. Oxygen is in air, so you make the call.
If I'm doing inlay work where laying CA over the inlay material, I certainly dont want bubbles or crystallization as it will degrade the overlay to the point that the inlay will be cloudy or worse.
I use a cool mist humidifier (which comes on in an instant) to blow fine mist over the CA causing its cure to accelerate slowly---no bubbles---no crystallization. You can also use a fine spray mister to do the same thing.
I've never had the luxury of keeping the CA in the refrigerator. My shop is non AC and in recent days in NE Oklahoma temps over 100degrees (21 days straight)
Old 07-20-2011, 10:27 AM   #9 (permalink)
Photos: 2
Default
Wow, did not know that we had Marines out there. I will try and type slower next time so you can read it :). Just kidding. Where do you get this "cool mist humidifier"?
Gary
Old 07-20-2011, 11:38 AM   #10 (permalink)
okiebugg's Avatar
Photos: 7
Default
Quote:
Gary
OH NOOOOOOOOO
Another jarhead is loose on society and he knows all the secrets about hurting people
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
