Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 11-30-2011, 03:46 PM   #1 (permalink)
Photos: 0
Default CA Glue Finish Chip Out
Does anyone have any suggestions for keeping the ends of the pen blank from chipping when you are doing a CA Glue finish?
nonimac is offline   Reply With Quote Top
Old 11-30-2011, 03:50 PM   #2 (permalink)
Joe Burns's Avatar
Photos: 19
Default
When and how are they chipping out. If happening when trimming the flash on the ends try using a sanding mill instead.
Ive had it chip before when I got too aggressive when trying to use a skew bring the edges back down. I rarely have to do this anymore and stick to wet sanding with micromesh.
Joe
Joe Burns is offline   Reply With Quote Top
Old 11-30-2011, 03:55 PM   #3 (permalink)
Photos: 0
Default
usually it happens when breaking the bushings free from the blanks. I tap them against the lathe to break them free, but try to do it very gently. I put about 10-15 coats, so I am thinking maybe less coats will be the key.
Advertisement
Old 11-30-2011, 04:00 PM   #4 (permalink)
Photos: 0
Default
Waxing the bushings helps alot
wouldentu2? is offline   Reply With Quote Top
Old 11-30-2011, 04:03 PM   #5 (permalink)
Jerryconn's Avatar
Photos: 28
Default
I'm sure you'll get several different ways of doing this ;) Do you coat your bushing with paste wax before starting your CA finish? Taping them is not the preferred method. IF I get stuck bushings I will, with the lathe off take a xacto knife and score the built up CA on the bushing side of the bushing to blank joint until the bushing come loose. The method I prefer is to not use bushings, I do my finishing between centers on the lathe. But like I said you will get quite a few different methods. If you want to use bushings coat them with paste wax (it only takes a dab smeared on with your finger) before starting. Just be sure to keep the wax off the blank.
__________________
Jerry
Jerryconn is offline   Reply With Quote Top
Old 11-30-2011, 04:28 PM   #6 (permalink)
wiset1's Avatar
Photos: 146
Default
You can buy the Delrin Bushings (pensbyhans dot com) which should resolve this, but honestly, I use the Delrin and due to the CA coating it still coats the Delrin bushings. With that being said I use an exacto knife to round the bushing to cut through the CA. After that the tap and angle of the bushing should break the seal. Once I have this blank off the bushings I square it on the sander again and pour thin CA on a paper towel and dab the fresh ends of the blank on to seal it all back up again so wet sanding doesn't put moisture into the wood. Hope that helps
__________________
wiset1 is offline   Reply With Quote Top
Old 11-30-2011, 04:39 PM   #7 (permalink)
JimB's Avatar
Photos: 0
Default
I prefer to do my ca finish between centers without any bushings. Just don't over tighten the tailstock agianst the blank as you don't want to flair the tubes.
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Old 11-30-2011, 05:13 PM   #8 (permalink)
Group Buy Coordinator
Monty's Avatar
Photos: 13
Default
I do all my CA finishing between centers with out bushings, just the blank between centers. I sometimes get a little too much CA over the edge and end up gluing the barrel to the live and/or dead center. I always score the hardened CA with an exacto knife to try and avoid the problem of the glue lifting off the wood. Sometimes the finish still will separate from the barrel. About 95%+ of the time, I've been successful regluing it back by using an extender tip on the regular tip of the glue bottle and placing a microdrop of thin CA on the end of the barrel. The thin CA will wick into the space and it will not be noticeable. If I get too much and it makes the edge uneven, I use a sanding mill to even the edge up.
Be very careful not to use too much CA or it can run down the barrel and glue the barrel to your fingers, DAMHIKT.
__________________
Mannie - Pearland, TX
I hate it when people steal my ideas before I think of them.
Monty is offline   Reply With Quote Top
Old 11-30-2011, 05:15 PM   #9 (permalink)
Drstrangefart's Avatar
Photos: 2
Default
I tap my bushings off, too and I find the finish damage during assembly. Try laying out some 600 grit deat flatand sanding the ends before assembly. It takes a light touch and some practice, but I almost never have those chipouts anymore. Spending time polishing and thinning the finish out helps, too. Really thick layers of CA chip out a lot more when you gotta knock the bushings off.
__________________
* Insert fart joke here *
Drstrangefart is offline   Reply With Quote Top
Old 11-30-2011, 05:55 PM   #10 (permalink)
Photos: 0
Default
You can remove the bushings half way thru clean up the edges and finish it with a thinner final set of coats.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
