| Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here. |
Welcome to penturners.org!You've found the home of The International Association of Penturners. You are currently viewing our site as a guest, which gives you limited access to view discussions, photos, and library articles.Consider joining our community today. You'll have full access to all of our content, be able to enter our contests, find local chapters near you, and post your questions and share your experience with our members all over the world. Membership is completely free!! If you have any problems with the registration process or your account login, please contact us. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Location: Middletown,PA via The Coal Region,Pittston, PA, USA.
Photos:
I maid a few stoppers and seem to have a problem getting a flush fit between the wood and the stopper. Not sure if threading the wood on the mandrel is the problem I drill the blank on the drill press which is straight.Once in a while I tap the hole which is hard to get straight. Has anyone had this problem
__________________
#2 (permalink) |
How are you squaring the end of the blank up? I usually drill the blank, then take a parting tool or a scraper (depending on how off it is) and square up the end of the blank. I think the only way to be sure you're going to get a flush fit is if you both tap and flush it without taking it out of the 4-jaw chuck.
__________________
Ok, first of all; I'm not 100% in love with your tone right now.
#6 (permalink) |
Assistant Moderator
Vendor Liaison Join Date: Aug 2007
Location: Lac du Bois - middle of nowhere, in the Great White North
Photos:
What I do is screw the bottle stopper onto the base as far as it will go. If it leaves a slight gap, I unscrew it...
The screw will stay in the bottle stopper. I take a pair of plyers and give it a final turn or two, and make sure that all of the larger threads are in the wood...then it should screw in perfectly fine! Andrew
__________________
"When it is dark enough, you can see the stars"
"He who can no longer pause to wonder and stand rapt in awe, is as good as dead; his eyes are closed." |
#7 (permalink) |
No Just a regular stock black n decker bit, then my mandrel bit. Ill apply some thin CA to the hole to help strengthen the wood and tap away. I was having some slipping before I used the CA. Just make sure its nice and dry before you set it up on your mandrel.
__________________
" I am the gatekeeper of my own destiny, and I will have my glory day in the hot sun"
![]() Last edited by el_d; 11-24-2008 at 09:16 PM. |
#8 (permalink) |
I'm assuming you're talking about the cone-shaped bottle stoppers.....I use the teardrop ones exclusively...the mandrel setup is different and doesn't need to be fit flush like the cone ones. Check out the ones at Woodcraft. Maybe you could just try those!
__________________
Wherever you go, there you are.
Write On, Brian Goulet The Goulet Pen Company Ashland, Va. www.GouletPens.com |
#9 (permalink) |
Well, one problem with the tear drop ones is there's no stainless steel option on them. The ones you're talking about are chrome and in time (year or so) it can start to pit and flake. It takes a while but eventually I expect they'll all fail with regular use.
__________________
#10 (permalink) |
That's a good point....Maybe I should ask Berea about making a stainless teardrop one. The cone ones are just not my flavor...I really don't like them. Plus, they don't seal as well as the o-ring ones. Not that I ever have a half bottle to save
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
