Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 04-28-2011, 04:30 PM   #1 (permalink)
Photos: 0
Default AC to AC converter question
There are three Heavy Duty sockets on this Converter. 1500W Max. I intend to step down 220 volts AC for my 110 volts AC equipment. I am puzzled with the red socket marked as FIXED 100VAC. Instructions does not explain. What does it mean or what is it's use? Thanks.
__________________
Stephen
Stephen is offline   Reply With Quote Top
Old 04-28-2011, 05:03 PM   #2 (permalink)
kirkfranks's Avatar
Photos: 9
Default
Stephen,
Is there any way to post a larger photo. The thumbnail does not get bigger so we cannot read it.
__________________
Kirk
Salisbury, MD
kirkfranks is offline   Reply With Quote Top
Old 04-28-2011, 05:50 PM   #3 (permalink)
Photos: 0
Default AC to AC Converter
Thanks . Sorry I am unable to upload a larger scanned attachment.
Here is what is written on the Card Box
Box Conventional Transformer
Single Function (Either step-up or step-down)
Continuous Use Design
With Enamel Paint Coating (serves as Insulation)
NEWSTAR AC to AC Converter
Features :
Input Voltage : AC 220V 50/60Hz or AC 110 50/60Hz
Output Voltage: AC 110v 50/60Hz or AC 220 50/60Hz
Output AC socket : Three Universal Sockets (one socket
with Fixed 100VAC
Socket with 3 wires (one is safety ground wire)
On/Off rocker switch with indicator lamp
Insulated base platform for safety insulation
Automatic thermal fuse
Glass fuse
Metal casing with superior air ventilation design
Overheat protection
Overload protection
Stephen
__________________
Stephen
Advertisement
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2013 by Penturners.org, LLC; All Rights Reserved
