Casual Conversation Off-topic, general chat. |
Welcome to penturners.org!You've found the home of The International Association of Penturners. You are currently viewing our site as a guest, which gives you limited access to view discussions, photos, and library articles.Consider joining our community today. You'll have full access to all of our content, be able to enter our contests, find local chapters near you, and post your questions and share your experience with our members all over the world. Membership is completely free!! If you have any problems with the registration process or your account login, please contact us. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Photos:
Not sure where this goes, so let's try the casual way :)
I am looking at getting started with applying logos to pens (possible business with a real estate agent acquaintance) and since colors are needed then decal paper seems the way to go. I am planning to print using a laser printer and there seem to be quite a few options from different vendors. Brief questions: Are all these papers created equal? If you have found that some are better than others, please share your favorite brand. Thank you! Fred
__________________
"It's tough to make predictions, especially about the future" Yogi Berra |
#2 (permalink) |
Following, I too would like to hear folks answers. Also, do you coat them before casting and if so with what and for what resin. Thanks.
Sent from my iPad using Penturners.org mobile app |
#3 (permalink) |
Photos:
I have used the Testors Decal Paper from Hobby Lobby.
I print the decal. Let it set overnight I spray with Krylon Non-yellowing Clear Gloss Let it set overnight. Another coat of Krylon Let it set overnight. Apply to the pen blank. Let it set overnight. Coat with 6 coats of CA. Let it set overnight. |
Advertisement |
#4 (permalink) | |
I have limited experience with decals, but the few times I tried it, it worked very nicely. I used Blinggasm Waterslide Decal Paper from Amazon and pretty much the same technique that Larry specified. It's most cost effective to print an entire sheet of decals at once. Then a couple coats of Krylon Clear Acrylic Coating Spray to fix the ink onto the decal sheet. Then cut up the individual decals and water slide them to your blanks. I messed around with some Micro Sol Setting solution, but am not sure it really made any difference. Once dried onto the blank, I put multiple coats of CA over it until the decal "disappeared" into the CA. It came out really nice.
__________________
![]() 'I asked the ink drop why it looked so sad. He said his mother was in the pen and he didn't know how long her sentence would be.' |
#6 (permalink) |
I've only used the lazertran paper, couldn't find any other around here. It's ok but it seems like a little more work than some of the others. Print it and then if applying to wood you soak the area where the decal is going with real turpentine it then drys with a white background. To get a clear background you cover with an oil based poly and the white turns clear. If I am doing pens I then put my normal CA finish on.
__________________
Rick I support The Pens for Canadian Peackeepers Project http://www.undergroundwoodworking.ca |
#7 (permalink) |
Photos:
Thanks everybody for the help and suggestions, I just placed some orders and sounds like I now have a plan for next weekend :)
__________________
#8 (permalink) |
Photos:
I've been printing decals on pens for a couple of years now and the paper I like best is the Laserjet Waterslide Decal Paper/White from Dr. Decal and Mr. Hyde in Australia. Trouble is that it costs an arm and a leg in shipping.
The paper has text on the back of the sheets - picture attached. Does anyone know who makes it (preferably with a store in the UK)? Very many thanks Paul |
#9 (permalink) |
__________________
Chuck Hutchings Indianapolis, In. You can see some pens at http:www.facebook.com/chuckspens |
#10 (permalink) | |
Photos:
I tried a couple different papers (can't remember the vendor or brand but both from Amazon), my experience is that spraying with the non-yellowing clear gloss Krylon makes a much bigger difference than the paper itself! I found that not only the Krylon helps protect the ink printed motif but it seems to "rigidify" the decal paper, making it slide more easily off the backing paper with much-diminished tendency to warp and fold on itself.
__________________
Bookmarks |
Thread Tools | |
Display Modes | |
