Transfer punches
KenV
Juneau, Alaska.
Yup -- and get a second set - they are handy for all kinds of stuff - including marking the center of a hole onto an underlying piece of goods.
Had the task earlier this year off marking and driling holes in 1/4 inch stainless steel
They were just the right tool for marking holes.
NewLondon88
Local Chapter Leader
Claremont NH
I'm not sure where I got them. I've had them for a long time, but they are pretty much the same. Maybe a little better quality/steel?
Could be .. but these are pretty tough so far. I've whacked them pretty
good with hammers, mallets .. even striking them on an anvil and
those dimples aren't showing any wear. But I do have multiple sets
so one of them I planned on beating up. Haven't hurt them yet.
Justturnin
Houston, Tx
I use these and they are surely a softer steel and will 'shroom up on the top but not an issue as the pen components are softer yet.
Crashmph
South Riding, VA
I have had to grind the dimple off of a few of mine for disassembly. Specifically on the zen Gran Torino Electra type when pushing out the post end.
ghostrider
Grand Rapids, Michigan
I've also experienced this problem with them, but that was when the loc-tite leaked into a tube and I tried to remove a transmission. :rolleyes:
FYI, but I think there is currently an Inside Track Club coupon for these.
NewLondon88
Claremont NH
I just looked mine over again and did some hammering. One set is
definitely softer than the other two. But I can't remember where I got
each set!
rsulli16
hi
just go get a set. i got the same HF set for dissasembly of pens i read about on here. only disassembled one or two pens, but have used the punches for all sorts of things since i've gotten them. Very handy things to have around the shop.
my two cents :)
Sulli
