Thich CA glue fumes - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Casual Conversation
  Forgot Password
Casual Conversation Off-topic, general chat.
Welcome to penturners.org!
Reply
Old 04-03-2017, 08:07 PM   #1 (permalink)
Photos: 34
Default Thich CA glue fumes
This is about the third time I have glued a bunch of blanks togethere but at first I thought it was seasonal allergies but from the research I did on thick CA glue was the fumes from it can cause a type of asthma problem that almost makes it hard to breathe feels like breathing through a straw and it causes a stuffy nose and bad coughing.
I guess its like a allergic reaction to the fumes but has anyone else experienced this.
It also kept me up the first time it happend maybe only had about 5 hours of sleep of a 24 hour day the next morning
Do also any new pen turners should might want to know about that if they use it because it is pretty dangerous glue.
penmaker134 is offline   Reply With Quote Top
Old 04-03-2017, 09:02 PM   #2 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Numerous people over the years here at IAP and probably many not on IAP have experienced the flu like symptoms. It will probably only get worse for you.
I turned for two years without a problem, then one day I got a sniffle. Two weeks later, I got what was like a sudden nasal drainage and flu like symptoms. Being the dummy that I was, I tried a third time to make a few pens a few weeks later and full fledge flu like symptoms including double vision.
After that, a Dust Collector immediately behind the lathe, a double filtered face mask.
I am told that ODERLESS CAs work just as well as regular CA and do not cause these symptoms. I haven't tried it yet, but I will soon.
__________________
Hank Lee
Good is the enemy of Best
leehljp is offline   Reply With Quote Top
Old 04-03-2017, 09:02 PM   #3 (permalink)
lorbay's Avatar
Photos: 134
Default
I use a fan or my dust extractor. Never smell the stuff.
Lin.
__________________
"If you come to a fork in the road Take It."
Yogi Berra.
lorbay is offline   Reply With Quote Top
Advertisement
Old 04-03-2017, 09:05 PM   #4 (permalink)
Photos: 34
Default
it just give me allergy symptons but def. gonna pick up a mask to glue tubes in for future only last about a week the first night is the worst cause it feels like breathing through a straw and it makes you not want to sleep.
Old 04-03-2017, 09:52 PM   #5 (permalink)
robutacion's Avatar
Photos: 4
Default
CA fumes are bad news, I'm actually doing at the moment some Dwarf Banksia pod samples as an order and I'm getting plenty of those fumes that I avoid like a bad smell, I use a chemical mask but I have found that, one of the simplest and most effective ways to prevent to breath those fumes is to put a small fan on one side of your face so that the fumes that will climb up into your nostrils, is blown away to the side, preventing you from getting that bad stuff into your lungs.
Yes, loss of sleep is also one of my main reactions when I get some of it, I don't have (yet) any other nasty reaction to it and I can saw that I use gallons of the super thin CA per year, the soaking action of the super thin CA is what creates the smoke.
I have never used odourless CA however if it works well, I would suggest all of those people that know they throw a reaction, to start using the odourless stuff, better safer than sorry (and why I never follow my own advice...?)
Cheers
George
__________________
"Don't give others what you don't like for yourself"
Email: nyodine@yahoo.com.au
Web-Store: https://www.georges-bits-of-timber.com/
robutacion is offline   Reply With Quote Top
Old 04-03-2017, 10:05 PM   #6 (permalink)
Photos: 0
Default
I had the cold like symptoms and switched to Bob Smith industries odorless CA at least 5 years ago and have done hundreds of CA pens and never had another problem. Try it you'll like it. I also never have any cracking with it. I only use the thin with craft foam as an applicator so little is wasted. This is important since you get half as much for twice as much.
wouldentu2? is offline   Reply With Quote Top
Old 04-03-2017, 11:03 PM   #7 (permalink)
TonyL's Avatar
Photos: 6
Default
I am not allergic to CA fumes (at least not yet), but I wear a organic vapor mask around applying it, and accelerator. I am not sure if it is protecting me, but I am just being cautious. I don't wear a mask when I an gluing tubes - I guess am not that cautious.
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Old 04-04-2017, 06:34 AM   #8 (permalink)
edstreet's Avatar
Photos: 2
Default
EVERYONE can and WILL have allergic reactions to CA fumes. Given enough exposure of it. Some are more sensitive than others. This is a very good case for ODORLESS CA, the problem is not there.
__________________
Anyone can COPY, it takes a *TRUE ARTIST* to CREATE
-- In times of universal deceit, telling the truth becomes a revolutionary act.
Design your own Polymer Clay Pen Blanks by Toni, Detailed 'CA' Article
edstreet is offline   Reply With Quote Top
Old 04-04-2017, 08:57 AM   #9 (permalink)
Photos: 1
Default
I don't get any nasal reactions to speak of with CA, but my eyes will water. Like others, I usually have a fan blowing across my work, or I step to the doorway and effectively apply the CA outside the shop.
One thing I have learned, and I learned this quickly, don't wear your TrendAirShield when applying CA... it sucks the fumes right into your enclosed face and right into your eyes and nose.
__________________
Chuck
Tellico Plains, TN
https://www.etsy.com/shop/TellicoTurnings
If you look for trouble, it will find you!
TellicoTurning is offline   Reply With Quote Top
Old 04-04-2017, 09:51 AM   #10 (permalink)
Photos: 0
Default
I use the Rockler Vac. attachment for the lathe For me it works great for sanding and CA.Actualy all pen work. I use Fien Turbo I with filter ,Bag and Onieda cyclone system.
tonylumps is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
blanks , glue , pens , penturners
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
