dogcatcher
Dogcatcher,
The instructions you quote (for 3-jaw chuck) do not apply to this chuck (4-jaw chuck).
The instructions will work, it doesn't matter if is it a 3 jaw 4 jaw or 100 jaws, that is the way to true up a chuck. But the problem is wood lathes do not have a tool rest capable of do that. All of Taig's lathes were designed to be trued up by the users.
If someone has a cross slide, even a drill press cross slide they may be able to rig up a cutter using a Dremel with a sanding drum as a cutter, but your runout will only get better if all your parameters are done correctly.
