streaked when i put the Ca clue finish
magpens
Canada
Please check your kit name ... doesn't look like a Mesa to me !
But that's kinda beside the point the results are very nice indeed !!!! . Love that turquoise ring !!!!
Repromander
San Bernardino
Seal
No i didn't seal the decals before hand good suggestion.maybe a small drop on each decal with lath like posting like CREID said? sure would like to spray over them with something first.Lath off.
CREID
Vancouver, wa
Krylon clear. I am currently using something from rustoleum in clear. I am fairly new to decals and I print my own, not store bought, and I put 3 light coats of clear on before I even cut the decal from the sheet and apply to the pen barrel. I have not used the store bought, so I can only speak from the limited experience I have printing my own.
Repromander
San Bernardino
good idea onRustoleum spray clear :) nai art from http://www.bostonnailart.com/
Woodchipper
Cleveland, TN
Overspraying seals the blank. Fishing rods require a coat of epoxy on the blank to seal it before any decals or hand writing is done.
JodyS
Orlando, FL
At the FLGAPG last month, someone demo'd decals. He said he'd done extensive research and testing on CA glue, and there was only ONE that he would recommend for that purpose. BGI SuperGold and SuperGold +. He applied the first coat of CA over the decal with the lathe off as mentioned above. I have the glue and the decals, just have to get my lathe back up and running and I'll be testing this for myself.
The Supergold makes some sense to me, since it was specially formulated to not destroy foam that it's being adhered to. If it's "kinder and gentler" on foam, it stands to reason it would be on other surfaces (decals) as well.
edstreet
No longer confused....
Foam safe is odorless. It does not generate heat like ECA does. I have videos of me putting supergold on my hand and spraying it with Indra-set and not getting chemical burns. Try that with ECA based CA like stick fast, and ez bond and the like.
It's also good for the lung as it will not cause allergy reactions over time.
