Pen Kits & Bushings From Different Places
BillyBoy63
Heyworth IL
Hey Boys & Girls
I buy 90% of my pen kits and bushings from PSI
My question has anyone tryed to use bushings from PSI and
use a pen kit from WoodTurning Store there kits look the same as PSI
Will they interchange or do you need there bushings for there kits
Brand name Legacy
If they interchange i tought i might give them a try a little cheaper but
i don't want to accumulate a whole bunch of bushings and then take a chance
in getting them mixed up
BillyBoy63
ed4copies
Local Chapter Manager
Racine, WI, USA.
This MAY not apply here, but there is a company in China that "knocks off" PSI and many other big name pen kits. HOWEVER, they are usually NOT the same dimensions (off by a few hundredths, but that DOES matter) and they are often made to a lower specification (nibs crush while assembling, transmissions don't work, etc). So, it is a better idea to buy bushings from PSI. Bushings will usually make dozens of pens and cost less than $5.
Dehn0045
US
I recommend ditching the bushings and TBC using calipers. But even if you use bushings, the calipers come in handy the verify bushing and part diameters. There is some variation in part diameter. Some kits have bushings that aren't even close to the part diameter, the most extreme example I've run into is with the PSI dragon kit.
magpens
Canada
I also recommend TBC and calipers.
Getting your bushings mixed up, or lost, or whatever is not a "chance" ... it's certainty !!
FrankH
Morgantown WV
Being a little older, I get a regular supply of prescription bottles. I use these to store my bushings. I just have to remember to return them to the bottle before I start a different pen.
